I'm trying to draw a spring but keep getting it wrong.
Use HELIX and SWEEP and check the similar threads at the bottom of this thread.
Where are you going wrong?
You can also use the Helix and Extrude (using Path option) in AutoCAD 2009.
Why not attach your file here?
I would probably use Sweep rather than Extrude with Path as suggested, but attach your file or at least a picture of something similar here.
You might also want to check the "Similar Threads" listed below.
you can use helix and for thickness use sweep command
