cyter Posted April 21, 2011 Posted April 21, 2011 I'm trying to draw a spring but keep getting it wrong. Quote
SLW210 Posted April 21, 2011 Posted April 21, 2011 Use HELIX and SWEEP and check the similar threads at the bottom of this thread. Quote
ReMark Posted April 21, 2011 Posted April 21, 2011 Where are you going wrong? You can also use the Helix and Extrude (using Path option) in AutoCAD 2009. Quote
JD Mather Posted April 21, 2011 Posted April 21, 2011 I'm trying to draw a spring but keep getting it wrong. Why not attach your file here? I would probably use Sweep rather than Extrude with Path as suggested, but attach your file or at least a picture of something similar here. Quote
ReMark Posted April 22, 2011 Posted April 22, 2011 You might also want to check the "Similar Threads" listed below. Quote
Cad64 Posted April 22, 2011 Posted April 22, 2011 Using Helix and Sweep commands: http://www.dailyautocad.com/2007/10/advanced-solid-modeling-in-autocad-2008.html Quote
rameshremo Posted April 23, 2011 Posted April 23, 2011 you can use helix and for thickness use sweep command Quote
cyter Posted April 23, 2011 Author Posted April 23, 2011 Thanks for the link. Easy to follow. Using Helix and Sweep commands: http://www.dailyautocad.com/2007/10/advanced-solid-modeling-in-autocad-2008.html Quote
