Does any way exist to find out all settings in Files Tab of Options via AutoLISP, then change them to desired values?
pBe,
thank you for your reply.
  pBe said:
Getenv
Setenv
I don't know how to use getenv and setenv, i.e. I have no knowledge about the name of the variables.
  pBe said:
(vla-get-files (vla-get-preferences (vlax-get-acad-object)))
The code is very good to get environment variables, so thank you for the help, but how to set variables?
Guest kruuger
few sample:
(setq *files*
 (vla-get-files
(vla-get-TempDirectory *files*)
(vla-put-TempDirectory *files* "C:\\Temp\\")
(vla-get-PrinterConfigPath *files*)
(vla-put-PrinterConfigPath *files* "\\\\ahi\\support\\CAD_Install\\LD6\ahi\\PLOTTERS")
ok ?
kruuger
updated the post, attached pdf for SETENV/GETENV rererence for you
as for vl
IAcadPreferencesFiles: This object contains the options from the Files tab on the Options dialog
Property values:
AltFontFile =
AltTabletMenuFile =
Application (RO) = #
AutoSavePath =
ColorBookPath =
ConfigFile (RO) =
CustomDictionary =
CustomIconPath =
DefaultInternetURL =
DriversPath =
EnterpriseMenuFile =
FontFileMap =
HelpFilePath =
LogFilePath =
MainDictionary =
MenuFile =
PageSetupOverridesTemplateFile =
PlotLogFilePath =
PostScriptPrologFile =
PrinterConfigPath =
PrinterDescPath =
PrinterStyleSheetPath =
PrintFile =
PrintSpoolerPath =
PrintSpoolExecutable =
QNewTemplateFile =
SupportPath =
TempFilePath =
TemplateDwgPath =
TempXrefPath =
TextEditor =
TextureMapPath =
ToolPalettePath =
WorkspacePath =
Methods supported:
GetProjectFilePath (1)
SetProjectFilePath (2)
(vla-put-QNewTemplateFile VarName "NewValue")
where VarName is product of
(setq VarName (vla-get-files (vla-get-preferences (vlax-get-acad-object))))
to check if an object has a specified property
(vlax-property-available-p VarName 'DriversPath)
or
(setenv QnewTemplate "NewValue")
Setenv variable name is case sensitive so be careful with that
Hope this helps
pBe and Kruuger,
thanks for your help.
  Ahankhah said:
Kruuger, thank you for your aim, but in my country the address is FILTERED:shock::cry::bloodshot::reallymad:.
That sucks.
Just a suggestion when setting your paths you may want to use strcat and read existing paths and add your own then update paths this way you dont stuff up the generic Autocad ones.
Every body like me about to load 2012 this will help setups as we 13 to do.
