OSnap not working in veiwport
I have my osnap settings set up with the typical ones turned on (endpoint, perpendicular, etc) but they don't seem to work when I go into a viewport, I have to right click and pick the osnap that I want to use at the time. Do you know why this would happen?
Do you have 3D object snap? Could you provide a screen shot? Is it in all drawings? Is the viewport 2D wireframe? Have you checked the Settings in OPTIONS>DRAFTING?
I can't duplicate, so I need some info.
Could this be from current state of OSNAPCOORD system variable?
Regards,
Mircea
I went back and tried it again, my osnap works when I do most commands except for when I zoom/window, it doesn't let me pick the first point using osnap unless I right click and pick the osnap that I want to use. Is this how it is with Autocad or is there something off with mine?
I actually just changed my OSNAPCOORD to 0 and it started to work :) Thanks Mircea
  • 11 years later...
Thanks
  • 7 months later...
It's great to know this
