UCS repetitive display
Tipo166
Hello All,
When debugging from Visual Studio and running the DLL, I am getting a repetitive display of the UCS that displays on the window but does not move or disappear when panning/zooming. Infact with each click (?) of the mouse wheel (normally used to zoom in/out) another instance of the UCS is displayed. Anyone else had this issue? Solution? Does not go away with minimizing, regen, only closing the dwg works...
What happens if you set the ucsicon variable to "Noorigin"?
