Hi.
I need help. How to set time on precise value in SUN & LOCATION panel in RENDER tab. There is only a very anprecise slider (aboute 8 min skip) or in Sun Properties window I can select time only every 15 min. I need to set time every minute to analyse the shadow on the building.
Thanks for help.
Is a one minute interval really practical when doing this type of analysis? Can a person discern the difference between 12:01 p.m. and 12:02 p.m for example?
You are right ReMark. Practically there is no difference between 12:01 and 12:02 but I need it to make some theoretical work. I want to check lisp that I have. Lisp is more comfortable in use because its working in 2D not in 3d so I don't have to build a model.
