[VBA AUTOCAD]Create a loop with variable selectionset
lubracali
I start from a situation like this
I have to create a loop for each iteration allows me to select segments of a group(in the picture I have 5 groups, marked in red), so I have 5 "boxes/containers"(in this case, can be any number) that list each segment of the corresponding group.
I tried to use
Dim objSset(J) As AcadSelectionSet
Dim J as integer
or
Dim objSset(J) As Collection
Dim J as integer
but I always got the error "Constant expression required".
What can I use to run something like this?
Private Sub cmdGruppi_Click()
Dim j As Integer
Dim objSset(j) As AcadSelectionSet
answer = vbYes
j = 1
Do
Name = j
Set objSset(j) = ThisDrawing.SelectionSets.Add(Name)
MsgBox "Choose all the segments in a group", vbOKOnly, "Group"
Me.Hide
objSset(j).SelectOnScreen
answer = MsgBox("Another group?", vbYesNo, "New group")
If answer = vbYes Then
MsgBox "yes", vbOKOnly, "yes"
ElseIf answer = vbNo Then
MsgBox "no", vbOKOnly, "no"
End If
j = j + 1
Loop Until answer = vbNo
End Sub
Is there any container for objects that can be used?
  • 1 month later...
I've just had a quick look at your post so I might have missed something, but what about adding each group of lines to an AutoCAD Group?
Dim oSSetGroup As AcadGroup
Set oSSetGroup = ThisDrawing.Groups.Add("SG") 'SG = group name as string
oSSetGroup.name  = "GroupName"
Dim AddItem(0) As AcadEntity
Set AddItem(0) = SSet(X1)                         'SSet(X1) are items from your selection set
oSSetGroup.AppendItems AddItem       'AddItem is the name of the AcadEntity in previous step
Then you can just call your group using the group name... e.g.
(command "copy" GroupName "")
An error will be thrown unless either the array size is set explicitly:
Dim objSset(4) As AcadSelectionSet
Or set up as a Dynamic array:
Dim objSset() As AcadSelectionSet
If a dynamic array is used (and it looks like that is the direction you are headed) then it would have to be “ReDim”ed as needed.
See this link for the procedure.
http://msdn.microsoft.com/en-us/library/aa140074(v=office.10).aspx
Edited by SEANT
SEANT - In the code discussed in the other thread (here) I ended up using "ReDim Array (variable) as XXXXX" and it worked fine. I didn't need to Dim it as a dynamic array to start with... Is this OK practice?
Variables are the usual method for working with dynamic arrays. It is just that the variable has to be assigned an integer value prior to Dim”ming” or Redim”ing”.
Looking back on the OP, the first two code snippets posted didn’t assign a value type until after the array was declared. The routine in the code tags, though, did declare; Dim j As Integer.
That may actually work okay due to the fact that Integer value types are automatically initialized to 0. The massage given at the error("Constant expression required") leads me to believe that dimming the array without a constant (or empty braces for a dynamic array) was the cause.
