Koalbee Posted April 1, 2011 Posted April 1, 2011 Does anyone have a lisp routine or script fr this please Thanks in advance guys Quote
BIGAL Posted April 5, 2011 Posted April 5, 2011 More info please do you want tables, lines of text (in a box ?), co-ords in blocks etc P N E Z ? copy to excel ? Quote
Koalbee Posted April 5, 2011 Author Posted April 5, 2011 Northings and Eastings in a table would be good and maybe the ability to copy to Excel too. Thanks Quote
eldon Posted April 5, 2011 Posted April 5, 2011 If you do a search for "Point Manager", you will find a very useful lisp by Lee Mac which will do a lot of what you need Quote
Koalbee Posted April 5, 2011 Author Posted April 5, 2011 Hi Eldon. Found it, but it doesn't quite do the tabulation within Autocad. Or maybe, I just can't manage it Thanks Koal Quote
eldon Posted April 5, 2011 Posted April 5, 2011 I didn't think that it gave a table, but it did output a coordinate file. Try searching for "Table of Coordinates" in the forum. You should be able to find what you are looking for. Quote
BIGAL Posted April 6, 2011 Posted April 6, 2011 heres an old example of xyz in a box ;SETOUTBOX.LSP ; program to draw setout details as a co-ord list ; 29/9/04 by alan houston (setvar "menuecho" 0) (setvar "SNAPMODE" 0) (SETQ OLDSNAP (GETVAR "OSMODE")) (setvar "OSMODE" 0) (defun xyz () (setq ans "") (setq char_found "") (while (/= char_found ",") (setq char_found (substr new_line x 1)) (setq x (+ x 1)) (setq ans (strcat ans char_found)) ) ;end while ) ;end defun (setq setsc (/ (getreal "\nEnter Dwg scale 1: ") 1000.0)) (setq stpt (getpoint "\nPick top left point for details ")) (setq xyzfiles (getfiled "\nENTER CO-ORD File name " "" "" 4)) (setq fopen (open xyzfiles "R")) (command "zoom" "E") (command "zoom" "c" stpt (* setsc 100.0)) (setq pt1 stpt) (setq txtht (* 2.5 setsc)) ; 2.5mm HIGH LETTERING (setq num 1) (setq llen (* 84.0 setsc)) (setq ydiff (* 4.5 setsc)) ; 4.5mm line spacing (setq stptx (car stpt)) (setq stpty (cadr stpt)) (setq txtpt (list (+ stptx (* 42.0 setsc)) (+ stpty (* 2.0 setsc)))) (command "text" "BC" txtpt txtht "" "xxxxx") (setq txtpt (list (+ stptx (* 42.0 setsc)) (+ stpty (* 7.0 setsc)))) (command "text" "BC" txtpt txtht "" "%%uSETOUT DETAIL") (setq pt2 (polar stpt 0.0 llen)) (command "line" stpt pt2 "") ;draw horizontal line (setq pt1 (polar stpt 4.7124 (* 5.75 setsc))) (setq txtpt (polar pt1 0.0 (* 9.0 setsc))) (command "text" "BC" txtpt (* 3.5 setsc) "" "POINT") (setq txtpt (polar pt1 0.0 (* 34.0 setsc))) (command "text" "BC" txtpt (* 3.5 setsc) "" "EASTING") (setq txtpt (polar pt1 0.0 (* 67.0 setsc))) (command "text" "BC" txtpt (* 3.5 setsc) "" " NORTHING ") (setq pt1 (polar stpt 4.7124 (* 8.0 setsc))) (setq pt2 (polar pt1 0.0 llen)) (command "line" pt1 pt2 "") ;draw horizontal line (setq pt1 (polar pt1 4.7124 (* 1.0 setsc))) (setq pt2 (polar pt1 0.0 llen)) (command "line" pt1 pt2 "") ;draw horizontal line below above (setq pt1 (polar pt1 4.7124 (* 1.0 setsc))) (setq pt2 (polar pt1 0.0 llen)) (command "line" pt1 pt2 "") ;draw horizontal line below above (setq pt3 pt1) ; sets pt to last line position ;(setq pt5 (polar pt3 1.5708 (* 1.0 setsc))) ; 1 mm above line (setq pt5 pt3) ; 0.5 mm above line (SETQ XX 1) (while (setq new_line (read-line fopen)) (PRINC XX) (setq x 1) (setq y 5) (xyz) (setq ptno ans) ;pull ptno out (xyz) (setq easting ans) (xyz) (setq northing ans) (setq pt3 (polar pt3 4.7124 ydiff)) (setq pt4 (polar pt3 0.0 llen)) (command "line" pt3 pt4 "") (setq pt5 (polar pt5 4.7124 ydiff)) (setq pt6 (polar pt5 0.0 (* 8.0 setsc))) (setq pt7 (polar pt5 0.0 (* 28.0 setsc))) (setq pt8 (polar pt5 0.0 (* 58.0 setsc))) (command "text" "BL" pt6 txtht "" ptno) (command "text" "BL" pt7 txtht "" EASTING) (command "text" "BL" pt8 txtht "" NORTHING) (SETQ XX (+ XX 1)) ) ; end while (command "line" stpt pt3 "") (setq pt3 (polar pt3 0.0 (* 18.0 setsc))) (setq stpt (polar stpt 0.0 (* 18.0 setsc))) (command "line" stpt pt3 "") (setq pt3 (polar pt3 0.0 (* 33.0 setsc))) (setq stpt (polar stpt 0.0 (* 33.0 setsc))) (command "line" stpt pt3 "") (setq pt3 (polar pt3 0.0 (* 33.0 setsc))) (setq stpt (polar stpt 0.0 (* 33.0 setsc))) (command "line" stpt pt3 "") (princ setsc ) (setq pt1 nil pt2 nil pt3 nil pt4 nil pt5 nil pt6 nil pt7 nil pt8 nil stpt nil ans nil SETSC NIL ) (SETVAR "OSMODE" OLDSNAP) (princ) Quote
Lee Mac Posted April 6, 2011 Posted April 6, 2011 Found it, but it doesn't quite do the tabulation within Autocad.Or maybe, I just can't manage it I might consider adding that ability to a future version perhaps Quote
