Project Cut Pattern on Folded Part.
Is there a way to project a cut features created within the flattened pattern onto a folded roll formed part.
Example cut out of flat pattern:
Will not project on folded model:
I believe I have seen it done in inventor...
Thanks
KC
Did 2010 have Unfold and Refold? If so - use that.
Do not make features in Flat Pattern.
If 2010 did not have Unfold/Refold then you will have to use Cut Across Bend with a little trick.
But I'm pretty sure Unfold/Refold was introduced in 2010.
Yes it does and it worked perfectly... Thanks JD...
KC
