VBG-FSDG Posted March 25, 2011 Share Posted March 25, 2011 Hello All. In the current drawing I am working in, when I copy a viewport using CO command it copies the viewport but nothing is seen in it. You cannot active it like a normal viewport; it turns into just a square. I do not have this problem in any of my drawings, just this one. If I copy the viewport by right clicking copy with a base point then paste it in the drawing, the viewport works fine. This is more time consuming then just using the CO command. Can someone please tell me why this is happening? Thanks in advance for any help. Quote Link to comment Share on other sites More sharing options...
nestly Posted March 26, 2011 Share Posted March 26, 2011 Post the drawing if possible Quote Link to comment Share on other sites More sharing options...
Cad64 Posted March 26, 2011 Share Posted March 26, 2011 My guess would be that there is a polyline drawn directly on top of your viewport so that when you try to copy the viewport, you are actually grabbing the polyline. Try using the Move command and see what happens. Quote Link to comment Share on other sites More sharing options...
SuperCAD Posted March 26, 2011 Share Posted March 26, 2011 Do you need to turn on pasted viewports in 2010? I know I have to in 2008. Quote Link to comment Share on other sites More sharing options...
VBG-FSDG Posted March 29, 2011 Author Share Posted March 29, 2011 Nestly - I dont think I can post drawings yet, still a newbie. Cad64 - I have a blank paperspace and created a viewport. So there is no polyline like you are suggesting. Thanks though. SuperCAD - How do you turn on pasted viewports? I am working in 2010 and havent heard that before. Quote Link to comment Share on other sites More sharing options...
SuperCAD Posted March 29, 2011 Share Posted March 29, 2011 In 2010, you don't have to turn them on. In previous version, if you C&P'd a viewport you needed to go into the properties of the viewport and turn it on (Misc -> On -> Yes or No). When you created the viewport, did you use the _-vports command/button or did you create a rectangle polyline and convert it to a viewport? Quote Link to comment Share on other sites More sharing options...
VBG-FSDG Posted March 29, 2011 Author Share Posted March 29, 2011 I used the vports button. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted March 29, 2011 Share Posted March 29, 2011 Why can't you post a drawing? Use "Go Advanced" then "Manage Attachment". I can't duplicate your problem here, either method of copy works fine here, try going through your system variables to see if some variable could control this. Quote Link to comment Share on other sites More sharing options...
alanjt Posted March 29, 2011 Share Posted March 29, 2011 After you copy the Viewport: Command: MV MVIEW Specify corner of viewport or [ON/OFF/Fit/Shadeplot/Lock/Object/Polygonal/Restore/LAyer/2/3/4] <Fit>: ON Select objects: AL Quote Link to comment Share on other sites More sharing options...
VBG-FSDG Posted March 29, 2011 Author Share Posted March 29, 2011 SLW210 - My drawing was to big so I had to delete my title block and some of my elevation. With that being said here the condensed version. alanjt - that worked but do I have to do that everytime? I copied it again after what you suggest worked and the same problem happened. Looks like I would have to do what you suggested everytime. Is there a way to make it stay on? FS-7.0.zip Quote Link to comment Share on other sites More sharing options...
alanjt Posted March 29, 2011 Share Posted March 29, 2011 Everything copied fine for me (v2009). The one you labeled as a copy, I had to turn on (method shown in previous post) first, but after that, everything copied as it should have. Quote Link to comment Share on other sites More sharing options...
nestly Posted March 29, 2011 Share Posted March 29, 2011 Apparently, if REGENAUTO is off, then (CO)pied viewports are turned off by default. Set REGENAUTO to 1, or turn them on manually after copy as described by alanjt Quote Link to comment Share on other sites More sharing options...
SLW210 Posted March 29, 2011 Share Posted March 29, 2011 I have the same problem as the OP in his drawing, CO works as it should in my drawings. Quote Link to comment Share on other sites More sharing options...
VBG-FSDG Posted March 29, 2011 Author Share Posted March 29, 2011 Thank you all for your help. It is working now. Thank you again. Quote Link to comment Share on other sites More sharing options...
alanjt Posted March 29, 2011 Share Posted March 29, 2011 Apparently, if REGENAUTO is off, then (CO)pied viewports are turned off by default. Set REGENAUTO to 1, or turn them on manually after copy as described by alanjt Makes sense. I've never seen a reason to turn REGENAUTO off. Quote Link to comment Share on other sites More sharing options...
