efgME Posted March 24, 2011 Share Posted March 24, 2011 Thanks in advance for any help with this issue. I was asked to convert a .DWG to a .PDF. The .DWG came from a manufacturer and displayed 3 pages worth of content that was seperated into 3 Engineering Drawings. The layout included all 3 pages. I want to Plot this document to a 3 Page PDF. Do I need to create 3 seperate layouts? How do I specify what part of the model goes into a particular layout? Is this a common problem? What is considered best practice for solving the problem. Quote Link to comment Share on other sites More sharing options...
Organic Posted March 24, 2011 Share Posted March 24, 2011 So all 3 layouts (inc. titleblocks) are located in Modelspae? if there were only 3 pages and you were never going to need to print/pdf them again, I'd just do it from model-space. Otherwise set up a paperspace viewport for each sheet. Quote Link to comment Share on other sites More sharing options...
efgME Posted April 4, 2011 Author Share Posted April 4, 2011 Hi Dink87522; Thanks for the tip. I went for your first suggestion. I will try your second suggestion next time the problem arises. Quote Link to comment Share on other sites More sharing options...
