Greetings everyone.
I was trying to draw the enlacements of a wire rope by applying the hatch command but when I facing curves, the hatch needs to rotate somehow. Is it that possible?
I manage to do it by using "measure" command and then with a use of a block, align it to path and then enter the segment length. (Attached image)
But I was wondering if there is a way to do it with hatch command or any other method.
Not that i am aware of..... thats how i would have achieved it as you have.
Here's a suggestion. Define a linetype with a diagonal line. You could start with the standard Zigzag type and turn it into Zig. Draw a polyline that follows the midline of the wire. Assign the Zig linetype to that polyline.
Yes, good idea. That way it will be available without doing the procedure every time. Thanks mate
