Varying text size in MTEXT
I am encountering a problem with MTEXT
In layout space I use 3/32" text height (matching my text style) for mtext, but sometimes when I try to change the top line to 1/8" height it becomes HUGE - just the line that I'm trying to change. It happens with certain blocks of mtext, but not with others. Anybody know what might be going on?
One solution is to create a separate text object, with its own style, for your top line. That way, if your style standards change, you can update everything just by redefining the style.
Not sure what's going on with your text height inside the Mtext.
