Having loaded a partial CUI file from an MNU file, it was displayed on the menu bar, and was working correctly.
I found a dimension error in one of the drawing routines.
I unloaded the CUI file and deleted the CUIx file.
Corrected the error and reloaded the MNU file.
I can load the CUI file, but I can not get it to display on the menu bar.
This is very frustrating - :x - Can anybody help?
Are you using menuload or loading from within the cui ? You have said both.
I've tried both several times and neither will display the menu on the menu bar.
  • 3 weeks later...
It's probably loaded, just pick a Workspace in the CUI, hit the Customise Workspace button and check whatever menus you want to add.
  • 2 weeks later...
1- Issue CUI command.
2- A dialog titled "Customize User Interface" opens.
3- Select curret Workspace.
3- In the "Properties" pane at the right, you can see the settings of the selected workspace.
4- Make sure that Menu bar is On. (See enclosed picture)
5- Select OK botton.
