DrCADD Posted February 25, 2011 Posted February 25, 2011 I have developed a handout for my students and graduates I thought I would share here: www.KishwaukeeCollege.edu/cad Hope it helps our cause. Quote
ReMark Posted February 28, 2011 Posted February 28, 2011 Welcome to the CADTutor forum and thank you very much for sharing your 2011 system variables lookup sheet. What prompted you to do this in the first place? Quote
DrCADD Posted February 28, 2011 Author Posted February 28, 2011 You can imagine what a problem AutoCAD's system variables can become in an educational setting. I wish they would make parts of the program unchangeable starting with a default user profile and default dimenion style. Quote
ReMark Posted February 28, 2011 Posted February 28, 2011 The default dimension style could be handle via a template and cross-checked using the CHECKSTANDARDS command. I would think a default user profile in an educational setting could be setup via the college's network. Quote
BlackBox Posted February 28, 2011 Posted February 28, 2011 Direct link to the handout: http://www.kishwaukeecollege.edu/cad/pdfs/ACAD_2011.pdf One could always use Visual LISP to implement system variables, and user profiles by way of ACAD.lsp, and/or ACADDOC.lsp. :wink: One could also maintain Application Icons with the use of the "Scripting.FileSystemObject" and "WScript.Shell" objects, searching through these directories for *.lnk files: (strcat "C:\\Documents and Settings\\" (getvar 'loginname) "\\Desktop") "C:\\Documents and Settings\\All Users\\Desktop" (strcat "C:\\Documents and Settings\\" (getvar 'loginname) "\\Application Data\\Microsoft\\Internet Explorer\\Quick Launch") ... then modifying the Arguments property of each resultant Shortcut Object. Hope this helps! Quote
Tankman Posted March 1, 2011 Posted March 1, 2011 Welcome to the forums and thanks for the post. Quote
DrCADD Posted February 23, 2012 Author Posted February 23, 2012 DrCADD said: I have developed a handout for my students and graduates I thought I would share here: www.KishwaukeeCollege.edu/cad Hope it helps our cause. www.cadproblems.us Quote
myself Posted February 24, 2012 Posted February 24, 2012 i've checked the file...thank you very much, tremendous work compiling all that information. Quote
