DIW_HDsupply Posted February 21, 2011 Share Posted February 21, 2011 Can someone explain to me why I keep having to flop the order of the "aubin" supplied steel catalog and the "AutoDesk" provided steel catalog in order to complete the tutorial. I've been doing this as a work around, because the correct pipe objects are not popping up. I have already regenerated the catalog several times and both AutoDesk and Aubin's catalogs are loaded and moved to the top of the list in the OPTIONS -> Mep Catalog Tab -> Pipe section... I'm at figure 6.33 in the provided online PDF. In order to continue I can't load one add then load the other.... (have book but prefer PDF) Obviously something is conflicting to keep the two catalogs from working together like they are supposed to.... I am lead to believe this is how it SHOULD work. Can someone PLEASE pont this NOB in the right direction. This is really distracting me from understanding this chapter.. and i know at this point I am going to have to re-start chapter 6 again, as I'm loosing focus on content. Is there a way to temporarily COMBINE the two? I don't want to "contaminate" the stock "AutoDesk" content, and I need to get through this without self terminating. Quote Link to comment Share on other sites More sharing options...
tzframpton Posted February 21, 2011 Share Posted February 21, 2011 This might be an AutoCAD Profile issue. Have you restarted the program after setting the paths? Quote Link to comment Share on other sites More sharing options...
DIW_HDsupply Posted February 21, 2011 Author Share Posted February 21, 2011 Yup, Sure did restart.. software.. then CPU, multiple times. I even tried the migration button, thinking maybe that the Aubin file was a 2010.. but honestly... I don't have full grasp of what that does either. I'm not sure if I haven't corrupted the "AutoDesk" 2011 catalog's at this point. DIW Quote Link to comment Share on other sites More sharing options...
tzframpton Posted February 21, 2011 Share Posted February 21, 2011 Any catalog that has gone haywire is an easy "Repair Options" fix so no worries. I would have to see exactly what's going on with it since it's third party. I have the 2010 book, not the 2011 and never used the tutorials so I can't recreate your scenario. Wish I could help. Quote Link to comment Share on other sites More sharing options...
DIW_HDsupply Posted February 21, 2011 Author Share Posted February 21, 2011 Doh.... Ok,,, so lets talk "Repair Options" ... so I can at least rule that out... and befor we get started.. will this require administrative rights... cuz i don't have any... DIW Quote Link to comment Share on other sites More sharing options...
tzframpton Posted February 21, 2011 Share Posted February 21, 2011 Yes it will, and you'll need the physical media. Quote Link to comment Share on other sites More sharing options...
DIW_HDsupply Posted February 21, 2011 Author Share Posted February 21, 2011 I can also post the two files..... Autocad MEP file and the Aubin Catalog.. AutoCad Mep set http://dl.dropbox.com/u/20790817/MAMEP%20Commercial.zip Parts Cat http://dl.dropbox.com/u/20790817/MAMEP%20Pipe.zip Ch 6 Tutorial 2011 http://dl.dropbox.com/u/20790817/AAMS_AutoCAD_MEP_2011_ch06.pdf Quote Link to comment Share on other sites More sharing options...
DIW_HDsupply Posted February 21, 2011 Author Share Posted February 21, 2011 Have a media disk, but the administrative rights.. not so much.. that's going to be pulling teeth with My Help Desk team... They don't just give that out unsupervised... Before I go down taht road.. I'd like to explore any other option.... FYI... 2011 saves in the 2010 format... you should be able to use and view my files... SHOULD.... acording to AutoDesk. AutoDesk is always honest... just not always forthcomming. DIW Quote Link to comment Share on other sites More sharing options...
DIW_HDsupply Posted February 21, 2011 Author Share Posted February 21, 2011 I do also have this installed on my home machine where i do have administrative rights.... so knowing how is a good thing... Knowledge is Power... so still would like to knwo how to "Repair". Quote Link to comment Share on other sites More sharing options...
