flem snopes Posted February 18, 2011 Posted February 18, 2011 I'm using ACad MEP 2010 and attempting to change Object Snap settings via the Drafting Settings. When I select settings I get: Which seems corrupted. If I click on, say, Tangent I get: Can this be fixed? Thanks for your help. Quote
Organic Posted February 18, 2011 Posted February 18, 2011 I'd try and do a repair installation (just pop the DVD in the drive and it should give you the option to repair the product). Quote
nestly Posted February 19, 2011 Posted February 19, 2011 Repair might work, but back up your CUI first as you'll lose some of your customizations. Personally, I think that's likely a driver issue. Quote
flem snopes Posted February 19, 2011 Author Posted February 19, 2011 Thanks... I don't know if a reinstall will work. Other workstations on our network have the same problem. I'll get my network administrator to look into it. Any other ideas? Quote
flem snopes Posted February 22, 2011 Author Posted February 22, 2011 Well, I guess the problem's moot for me. Just installed Revit MEP 2011 and problem solved. Thanks all. Quote
