Hello!
When I open Revit an error appears sayin that it is not possible to find "Structural Analysis-DefaultRUSRUS.rte" file.
Can anyone tell me where to find it?
Looks to me that it's pathed to template file that doesn't exists or been moved. You can change the default template by clicking Settings menu, Options then File Locations tab. Under Default template file click Browse; most of the templates can be found at this location: C:\Documents and Settings\All Users\Application Data\Autodesk\RST 2009\Imperial Templates\Structural Analysis-default.rte.
Good luck.
-Dom
Thank you.. There is no such folder "imperial templates" and I just installed this version! I have been declicked something!?
Might be Metric, depending on the installtion type you choosed.
Under metric there are "Structural Analysis-DefaultMetric.rte" and "Structural Analysis-DefaultMetric-Up.rte". Which one shall I use and wish is better?
I would say you'll have better luck with this one: Structural Analysis-DefaultMetric.rte. You'll want to modify it to fit your needs as you learn more.
