khoshravan Posted February 14, 2011 Share Posted February 14, 2011 This is a geometry question, but I think folks here can help me to find a solution to draw it with CAD capabilites I have 2 points and a line given (both points on one side of line) I want to draw a circle so that it passes through two points and tangent to the given line. I tried a little bit but seams not be so easy (at least for me) Any idea. I have to say that still I couldn't solve the geometry of the question but there might be a solution in ACAD. Quote Link to comment Share on other sites More sharing options...
Organic Posted February 14, 2011 Share Posted February 14, 2011 Draw -> Circle -> 3 Points Click the two points then the line (which the circle will then be tangential to). Quote Link to comment Share on other sites More sharing options...
khoshravan Posted February 14, 2011 Author Share Posted February 14, 2011 Draw -> Circle -> 3 Points (which the circle will then be tangential to). clicking the line, doesn't insure that it will be tangent. Quote Link to comment Share on other sites More sharing options...
Organic Posted February 14, 2011 Share Posted February 14, 2011 Sorry, forgot the key point: Only have the 'Tangent' Osnap on when selecting the line (the 3rd point). Quote Link to comment Share on other sites More sharing options...
Michaels Posted February 14, 2011 Share Posted February 14, 2011 Follow the steps , circle : 3p 1st point 2nd point Right-Click with the mouse after holding down the Shift button and choose Tangent Select the Line. Congratulations . Michaels Quote Link to comment Share on other sites More sharing options...
Jack_O'neill Posted February 14, 2011 Share Posted February 14, 2011 Follow the steps , Right-Click with the mouse after holding down the Shift button and choose Tangent Michaels OR, simply type TAN at this point if you've changed your right click to do something besides displaying the osnap menu. Quote Link to comment Share on other sites More sharing options...
khoshravan Posted February 15, 2011 Author Share Posted February 15, 2011 Follow the steps , circle : 3p 1st point 2nd point Right-Click with the mouse after holding down the Shift button and choose Tangent Select the Line. Congratulations . Michaels Dear All Thanks. I learned that it is possible to input new snap command "tan" in the middle of another command. Very nice solution. Quote Link to comment Share on other sites More sharing options...
NAUTILUS Posted May 12, 2013 Share Posted May 12, 2013 amazing solution, just out of curiosity, does anyone knows the geometrical solution? ( without using CAD options) Quote Link to comment Share on other sites More sharing options...
JD Mather Posted May 12, 2013 Share Posted May 12, 2013 amazing solution, just out of curiosity, does anyone knows the geometrical solution? ( without using CAD options) Draw a circle with center at point 1 to point 2. Draw a circle with center at point 2 to point 1. Draw line from intersection of circle 1 and 2 perpendicular to the line. The third point is now known. Quote Link to comment Share on other sites More sharing options...
eldon Posted May 12, 2013 Share Posted May 12, 2013 Draw a circle with center at point 1 to point 2.Draw a circle with center at point 2 to point 1. Draw line from intersection of circle 1 and 2 perpendicular to the line. The third point is now known. I just tried that and it did not work for me. Could you please post a screen shot to show your construction? Thank you. Quote Link to comment Share on other sites More sharing options...
Organic Posted May 12, 2013 Share Posted May 12, 2013 I just tried that and it did not work for me. Could you please post a screen shot to show your construction? Thank you. I tried it and for the case I tried, it worked on one intersection point where the two original circles overlapped (the intersection point closest to the line) although failed on the other intersection point. Quote Link to comment Share on other sites More sharing options...
eldon Posted May 12, 2013 Share Posted May 12, 2013 (edited) I am afraid that JD Mather mis-read the latest request that was for a Geometrical solution, and his solution must be said to be incorrect. After a bit of delving, I think that the Tangent-Secant Theorem is the geometrical solution. Given two points A and B and a tangent line, then proceed thusly:- produce the line AB to meet the tangent line at C. Then the length CD is given by the equation CB x CA = CD² A calculator is needed (probably), but there are graphical solutions. Edited May 13, 2013 by eldon corrected expression Quote Link to comment Share on other sites More sharing options...
Tyke Posted May 12, 2013 Share Posted May 12, 2013 I am afraid that JD Mather mis-read the latest request that was for a Geometrical solution, and his solution must be said to be incorrect. After a bit of delving, I think that the Tangent-Secant Theorem is the geometrical solution. Given two points A and B and a tangent line, then proceed thusly:- produce the line AB to meet the tangent line at C. Then the length CD is given by the equation AB x AC = CD² A calculator is needed (probably) eldon, how would that work if the line AB was parallel to the tangent line CD? You would never get an intersection. Honestly though, I can't see how to do it. Quote Link to comment Share on other sites More sharing options...
eldon Posted May 12, 2013 Share Posted May 12, 2013 I was giving a general solution. The case if the two points were parallel to the tangent line would be simplicity itself, because the angle at the circumference is half the angle at the centre. Quote Link to comment Share on other sites More sharing options...
NAUTILUS Posted May 13, 2013 Share Posted May 13, 2013 i'm afraid its not the right solution. Quote Link to comment Share on other sites More sharing options...
NAUTILUS Posted May 13, 2013 Share Posted May 13, 2013 (edited) .... A calculator is needed (probably) then its not the geometric solution. what I mean by geometric solution is pure drawing, no calculations. thanks anyway Edited May 13, 2013 by NAUTILUS Quote Link to comment Share on other sites More sharing options...
eldon Posted May 13, 2013 Share Posted May 13, 2013 (edited) I was expecting that you could create a graphical solution for the term CA x CB = CD², and that is why I put the (probably) at the end. You have a rectangle with sides CA and CB. All you have to do is to find the square of equal area which will give you CD. Over to you now. Edited May 13, 2013 by eldon corrected expression - oops Quote Link to comment Share on other sites More sharing options...
eldon Posted May 13, 2013 Share Posted May 13, 2013 In fact, here is a link to do exactly that O ye of little faith Quote Link to comment Share on other sites More sharing options...
eldon Posted May 13, 2013 Share Posted May 13, 2013 In fact, I have just spotted my deliberate mistake. In the posted picture, the equation should be CA x CB = CD² Quote Link to comment Share on other sites More sharing options...
eldon Posted May 13, 2013 Share Posted May 13, 2013 eldon, how would that work if the line AB was parallel to the tangent line CD? You would never get an intersection. Honestly though, I can't see how to do it. Apologies for my previous answer. it was due to the fact that my brain skipped a couple of steps before my fingers hit the keyboard. If A and B are parallel to the tangent line, then the median bisector of AB would intersect the tangent line at right angles, i.e. the intersection point would be the tangent point. This is a special case, although if you took the mathematics, you could probably convince yourself that CD was the average of CA and CB Then the circle could be constructed by using median bisectors, or the fact that the angle at the circumference is twice the angle at the centre Quote Link to comment Share on other sites More sharing options...
