mirko vucetich Posted September 25, 2008 Posted September 25, 2008 I was using the pulled pipe feature from the Bentley Plant XM program that operates with AutoCAD 2007 (My version is Autodesk Building Systems). It works very well except when I try to plot from paper space. I have several view ports (in paper space) that shows bent pipe (front, side and 3-D Isometric views). On screen the views give me the desired affect of continuous bends with no indication of break lines in the pipe. This is what I wanted. When I try to plot this drawing from paper space, the plot shows breaks in the pipe as if there are two seperate components joined together (only in the vertical runs) not the horizontal runs. Model space works fine but paper space is where I'm having difficulties. I applied the hide, hidden, 3-D hidden commands and I also changed the proxy graphics, optional functions (from the pull down menus) profiles etc... to try to eliminate this situation but nothing seems to work. Has anyone had/have this problem? Could this be an easy fix? Quote
Strix Posted September 25, 2008 Posted September 25, 2008 and they're not on 'non-plot' layers? Just out of curiosity... not Bentley the car manufacturer? Quote
