markjohnsonii Posted February 7, 2011 Posted February 7, 2011 (edited) Hi there. Thank you very much. Edited September 15, 2016 by markjohnsonii Quote
ReMark Posted February 7, 2011 Posted February 7, 2011 Why not bring them into MEP with the PDFATTACH command, use the Scale by Reference feature then trace over them? I don't put much faith in conversion software as you sometimes spend a great deal of your time cleaning it up so it works the way you want. Just my opinion. Others may (and probably will) disagree. Quote
designerstuart Posted February 7, 2011 Posted February 7, 2011 i've not used one i liked yet :-( Quote
markjohnsonii Posted February 7, 2011 Author Posted February 7, 2011 ReMark said: Why not bring them into MEP with the PDFATTACH command, use the Scale by Reference feature then trace over them? I don't put much faith in conversion software as you sometimes spend a great deal of your time cleaning it up so it works the way you want. Just my opinion. Others may (and probably will) disagree. Ahhh ok well that is a great idea. I will keep this in mind. Thanks so much! Quote
SLW210 Posted February 7, 2011 Posted February 7, 2011 See Similar Threads @ the bottom of this page. I have had my best success with Ghostscript and GSview, but I usually go with the PDF underlay, scale and trace method when necessary. Best bet is to see if you can get the DWG. Try http://cadpanacea.com/ he has some excellent tips as well. Quote
mralchemy Posted May 24, 2011 Posted May 24, 2011 http://www.convertpdftodwg.co.uk converts drawings for £10 each results are very good considering the small costs They did me free samples I suggest emailing them a test pdf Quote
alanjt Posted May 24, 2011 Posted May 24, 2011 ReMark said: Why not bring them into MEP with the PDFATTACH command, use the Scale by Reference feature then trace over them? I don't put much faith in conversion software as you sometimes spend a great deal of your time cleaning it up so it works the way you want. Just my opinion. Others may (and probably will) disagree. Especially nice since you can use OSnaps on an attached PDF. Quote
Organic Posted May 25, 2011 Posted May 25, 2011 mralchemy said: http://www.convertpdftodwg.co.uk converts drawings for £10 eachresults are very good considering the small costs They did me free samples I suggest emailing them a test pdf 1. You spammed this in two threads. 2. I had a look at your site and watched the YouTube video of the conversion. The conversion is of surprisingly high quality actually. However as can be seen from the video, all you are doing is running the pdf through this program: http://www.autodwg.com/pdf-to-dwg-converter/Buynow.htm Considering that program only costs 200 pounds or so, why would anyone get you to convert 50 drawings or the other special packages available on your website (except as a one off only perhaps)? Quote
