todes Posted February 7, 2011 Posted February 7, 2011 Dear All, It has been some time but I really could use the expert help of the forum again. I'm working on a landscape model of the stourhead garden and it has been going great. there is just one last thing I have to do and off Corse this is not working. i want to drape the roads in the garden over the elevation model. To do this is was thinking of using shape merge cutting the roads out of the landscape. However when i select the landscape mesh i cannot select the road mesh and vice versa. images will follow soon the terrain has been made with quick serve and modified in 3ds max (this makes the drape function in quick serve drape function undesirable) the roads are closed polylines from AutoCAD Quote
Raudel Solis Posted March 21, 2011 Posted March 21, 2011 if you have an elevation map you could use displace modifier and use your elevation map .jpg/picture and adjust the strenght Quote
