KristenLovesBunnies Posted February 6, 2011 Posted February 6, 2011 Hi All, I'm new here and to AutoCAD. I'm having issues with a continuous arc segment that I created and then mirrored as part of a flourish on a headboard I'm designing. When I go to plot the layout, the mirrored line comes out super thick, even though I select the whole drawing to plot at .05mm thickness... Any suggestions? Thanks! Kristen Quote
CyberAngel Posted February 7, 2011 Posted February 7, 2011 It's possible that you have somehow overridden the thickness of that one arc. Even though the drawing and the layer have their own defined thicknesses, you can give a particular thickness to one particular object. Check the Properties for the arc. If its thickness is not ByLayer, set it to ByLayer. If it is ByLayer already, the Properties may tell you where the trouble is. Welcome to the forum! Quote
