Lisp help Selecting multi lines and labeling them
Try change this line on:
cTxt (rtos (cvunit (+ (fix eLen) 1.) "in" "feet")2 0)
~'J'~
Hello Fixo,
The latest change did not seem to yield correct rounding, 5" is the cutoff for rounding up. Lines that are less than XX'-5" are rounding down, lines that are greater than XX'-5" are rounding up. Any ideas how to fix this?
Thanks
JB
  • 1 year later...
  • 1 year later...
Hello,
I am not familiar with Autolisp but this code was very useful for me. What would be even greater is if one more adjustment should exist: to put text above or below the line. I would appreciate if someone could put that in this code.
Regards
Sasa
  • 5 years later...
Hello
now i use auto cad 2022 and these lisps give me error and don't work can someone help me about that ??
  • 11 months later...
On 2/6/2011 at 11:52 AM, Tharwat said:
Thanks for the encouragement .:)
So comments are welcome anytime .
(defun c:Lentxt (/ ss)
 (if (setq ss (ssget "_:L" '((0 . "LINE"))))
    (lambda (i / ss1 e dis pt1 pt2 pt3)
      (while
       (setq ss1 (ssname ss (setq i (1+ i))))
         (setq e (entget ss1 ))
      (setq dis (distance (setq pt1 (cdr (assoc 10 e)))(setq pt2 (cdr (assoc 11 e)))))
      (cond ((< (car pt1)(car pt2))
         (setq pt3 (polar pt1 (setq ang (angle pt1 pt2)) (/ dis 2.)))
        ((> (car pt1)(car pt2))(setq pt3 (polar pt2 (setq ang (angle pt2 pt1)) (/ dis 2.)))
        (entmakex (list (cons 0 "TEXT")
              (cons 10 (polar pt3 ang 0))
                 (cons 1 (rtos dis 2))
               (cons 50 ang)
                     (cons 40 (getvar 'textsize))))
    -1
 (princ "\n No Line(s) selected")
Thanks.
Tharwat
hey is there some lisp like this to instead of getting lenght get me something from attribute?? ❤️ pleasseee help
You need to elaborate what you are after a bit further and if it is supported with a DWG then that would be much better.
  • 1 year later...
On 2/6/2011 at 4:05 AM, Smirnoff said:
I slightly modified your code :)
(defun c:lmark(/ aDoc cTxt eLen ePar iAng iDr lPnt lSet oldSize sPar tWid)
 (vl-load-com)
 (defun Add_Masked_MText(Str Pt Hei Wid wiF Ang Mask
		  / oOsn cLay cTxt actSp nTxt
		  oDxf nDxf mPt xPt aDoc aSp lFlg)
 ; (Add_Masked_MText <Str> <Pt> <Hei> <Wid> <wiF> <Ang> <Mask>)
 (setq oOsn(getvar "OSMODE")
aDoc(vla-get-ActiveDocument
		(vlax-get-acad-object))
cLay (vla-get-ActiveLayer aDoc)
aSp(vla-get-ActiveSpace aDoc)
   ); end setq
   (if(= 1 aSp)
     (setq aSp(vla-get-ModelSpace aDoc))
     (setq aSp(vla-get-PaperSpace aDoc))
     ); end if
    (if(= :vlax-true(vla-get-Lock cLay))
     (vla-put-Lock cLay :vlax-false)
     (setq lFlg T)
   ); end progn
); end if
    (if(= 1.0 wiF)
 (setq cTxt(strcat "\\pxqc;" Str))
 (setq cTxt(strcat "\\pxqc;{\\W" (rtos wiF) ";" Str "}"))
); end if
       (setq nTxt(vla-AddMText aSp
	    (vlax-3D-point '(0.0 0.0 0.0)) 1.0 cTxt))
(vla-put-Height nTxt Hei)
(vla-put-Width nTxt(+ Wid(/ Hei 2)))
(vla-put-BackgroundFill nTxt -1)
(setq oDxf(entget(vlax-vla-object->ename nTxt))
      nDxf(subst (cons 45 Mask)(assoc 45 oDxf)oDxf)
       ); end setq
 (entmod nDxf)
 (vla-getBoundingBox nTxt 'mPt 'xPt)
 (setq mPt(vlax-safearray->list mPt)
       xPt(vlax-safearray->list xPt)
       mPt(vlax-3d-point
	      (list(+(car mPt)(/(-(car xPt)(car mPt))2))
		 (+(cadr mPt)(/(-(cadr xPt)(cadr mPt))2))
			 0.0))
		); end setq
         (vla-Move nTxt mPt(vlax-3D-point Pt))
  (if(and(> Ang 0)(<= Ang pi))
     (vla-Rotate nTxt(vlax-3D-point Pt)(- Ang(/ pi 2)))
     (vla-Rotate nTxt(vlax-3D-point Pt)(+ Ang(/ pi 2)))
   ); end if
    (if lFlg
       (vla-put-Lock cLay :vlax-true)
     ); end if
  nTxt
 ); end of Add_Masked_MText
 (if(not lab:Size)(setq lab:Size(getvar "TEXTSIZE")))
 (setq oldSize lab:Size
lab:Size
   (getreal
     (strcat "\nText size <"(rtos lab:Size)">: ")))
 (if(null lab:Size)(setq lab:Size oldSize))
 (princ "\n<<< Select lines and curves to label >>> ")
 (if(setq lSet(ssget '((0 . "*LINE,ARC,ELLIPSE,CIRCLE"))))
     (setq aDoc(vla-get-ActiveDocument(vlax-get-acad-object)))
     (vla-StartUndoMark aDoc)
     (foreach l(vl-remove-if 'listp(mapcar 'cadr(ssnamex lSet)))
(setq sPar(vlax-curve-getStartParam l)
	     ePar(vlax-curve-getEndParam l)
	     eLen(-(vlax-curve-getDistAtParam l ePar)
		      (vlax-curve-getDistAtParam l sPar))
             lPnt(vlax-curve-getPointAtDist l(/ eLen 2))
             iDr(vlax-curve-getFirstDeriv l
		  (vlax-curve-getParamAtPoint l lPnt))
	     iAng(- pi
		    (atan
		      (/(car iDr)
			(if(= 0.0(cadr iDr))(* 2 pi)(cadr iDr)))))
             cTxt(strcat(rtos eLen 2 0)"'")
             tWid(caadr
		   (textbox
		      (list(cons 1 cTxt)
			 (cons 40 lab:Size)(cons 41 0.)))
	     ); end setq
(Add_Masked_MText cTxt lPnt lab:Size (+ tWid(/ lab:Size 3)) 0.8 iAng 1.0)
); end foreach
       (vla-EndUndoMark aDoc)
     ); end progn
   (princ "\n<!> Nothing selected <!> ")
   ); end if
 ); end of c:lmark
can you please make this work for 2022 autocad ? thanks
 (vl-load-com)
   ); end setq
   (if(= 1 aSp)
     ); end if
     (setq lFlg T)
   ); end progn
); end if
    (if(= 1.0 wiF)
); end if
       ); end setq
 (entmod nDxf)
       mPt(vlax-3d-point
			 0.0))
		); end setq
   ); end if
    (if lFlg
     ); end if
  nTxt
lab:Size
   (getreal
	     iAng(- pi
		    (atan
		      (/(car iDr)
             tWid(caadr
		   (textbox
		      (list(cons 1 cTxt)
	     ); end setq
); end foreach
     ); end progn
   ); end if
 ); end of c:lmark
