Lisp help Selecting multi lines and labeling them
I have a lisp routine that labels lines with there lengths but i want to grab multiple lines and get it to label them with there lengths. Can any one help me?
(defun c:tl ()
(setq dscal (getvar "dimscale"))
(setq lspace (* 9.0 (/ dscal 96.0)))
(setq dimconv (/ 96.0 dscal))
(command "_.style" "jaytxt" "romans" "0" "0.80" "" "" "" "")
(command "regenauto" "OFF")
;----------set initial variables to nil-------------------------
(setq ent1 nil)
(setq pt1 nil)
(setq pt2 nil)
(setq xpt1 nil)
(setq ypt1 nil)
(setq xpt2 nil)
(setq ypt2 nil)
(setq pt1a nil)
(setq pt2a nil)
(setq tenl nil)
(setq tenl2 nil)
(setq tenf nil)
(setq tend nil)
(setq elo nil)
(setq aten nil)
(setq atenconv nil)
(setq txtjust nil)
(setq atenconvro nil)
(setq atenro nil)
(setq txtror nil)
(setq txtro nil)
(setq petxtd nil)
(setq ptltxtd nil)
(setq ptxt nil)
(setq petxt nil)
(setq ptltxt nil)
(setq txt nil)
;---------user input-----------------------------------------------------
(setvar "osmode" 0)
(prompt "Pick joist line")
(while (= ent1 nil)
      (setq ent1 (entsel))
); end while
(setq ent1i ent1)
(setq ent_1 (entget (car ent1)))
(setq jspi (cdr (assoc 10 ent_1)))
(setq jepi (cdr (assoc 11 ent_1)))
(setq jspx (car jspi))
(setq jspy (cadr jspi))
(setq jsp2 (list jspx jspy))
(setq jepx (car jepi))
(setq jepy (cadr jepi))
(setq jep2 (list jepx jepy))
;(setq pt1 (getpoint "\n Pick point for LIVE end of tendon"))
; (setq xpt1 (car pt1))
; (setq ypt1 (cadr pt1))
; (setq pt1a (list xpt1 ypt1))
; (setvar "osmode" 161)
; (setq pt2 (getpoint pt1a "\n Pick point for OPPOSITE end of tendon"))
; (setvar "osmode" 1)
; (setq xpt2 (car pt2))
; (setq ypt2 (cadr pt2))
; (setq pt2a (list xpt2 ypt2))
(setq pt1a jsp2)
(setq pt2a jep2)
(setq aten (angle pt1a pt2a))
(setq mpt1 (/ (distance pt1a pt2a) 2.0))
(setq mpt (polar pt1a aten mpt1))
(setq tenl (+ (distance pt1a pt2a) 4.0))
(setq tenl2 (/ tenl 12.0))
(setq tenf (fix (+ tenl2 0.501)))
;--------ROUNDING UP FUNCTION-------------------
(if (> tenl2 tenf)
    (setq tend (+ tenf 1)))
(if (<= tenl2 tenf)
    (setq tend tenf))
(if (>= tend 9.0)
    (setq tenda (* (fix (+ (/ tend 2.0) 0.5)) 2.0))
    (setq tenda tend))
(setq tenda tenda)
;-------TEXT JUSTIFICATION----------------------------------------
(setq atenconv (* 180.0 (/ aten pi)))
(if (and (>= atenconv 0.0) (<= atenconv 90.1))
    (setq txtjust "mc"))
(if (and (> atenconv 90.1) (<= atenconv 270.1))
(if (> atenconv 270.1)
(setq atenro (- aten (/ pi 2.0)))
;--------TEXT POSITIONING----------------------------------------
    (setq petxtd (- 0.0 lspace)))
    (setq petxtd lspace))
(if (>= atenconv 270.1)
; (if (and (>= atenconv 0.0) (<= atenconv 90.0))
;     (setq ptltxtd (- 0.0 2.0)))
; (if (and (> atenconv 90.0) (<= atenconv 270.0))
;     (setq ptltxtd 2.0))
; (if (> atenconv 270.0)
; (setq ptxt (polar pt1a aten (- 0.0 16.0)))
(setq petxt (polar mpt atenro petxtd))
; (setq ptltxt (polar ptxt atenro ptltxtd))
    (setq txtror aten))
    (setq txtror (- aten pi)))
    (setq txtror aten))
(setq txtro (* 180.0 (/ txtror pi)))
;-------TENDON LENGTH TEXT--------------------------------------
(setq txti (rtos tenda 2 0))
(setq txt (strcat txti "'"))
;-------TEXT PLACEMENT------------------------------------------
(setvar "osmode" 0)
(command "_.layer" "_m" "s-tech-jlen" "_c" "1" "" "")
(command "_.text" "_s" "jaytxt" "_j" txtjust petxt "6" txtro txt "")
;;;;----end of program-------------------------------------
) ;end defun
Edited by SLW210
Added Code Tags!!
I slightly modified your code :)
(defun c:lmark(/ aDoc cTxt eLen ePar iAng iDr lPnt lSet oldSize sPar tWid)
 (vl-load-com)
 (defun Add_Masked_MText(Str Pt Hei Wid wiF Ang Mask
		  / oOsn cLay cTxt actSp nTxt
		  oDxf nDxf mPt xPt aDoc aSp lFlg)
 ; (Add_Masked_MText <Str> <Pt> <Hei> <Wid> <wiF> <Ang> <Mask>)
 (setq oOsn(getvar "OSMODE")
aDoc(vla-get-ActiveDocument
		(vlax-get-acad-object))
cLay (vla-get-ActiveLayer aDoc)
aSp(vla-get-ActiveSpace aDoc)
   ); end setq
   (if(= 1 aSp)
     (setq aSp(vla-get-ModelSpace aDoc))
     (setq aSp(vla-get-PaperSpace aDoc))
     ); end if
    (if(= :vlax-true(vla-get-Lock cLay))
     (vla-put-Lock cLay :vlax-false)
     (setq lFlg T)
   ); end progn
); end if
    (if(= 1.0 wiF)
 (setq cTxt(strcat "\\pxqc;" Str))
 (setq cTxt(strcat "\\pxqc;{\\W" (rtos wiF) ";" Str "}"))
); end if
       (setq nTxt(vla-AddMText aSp
	    (vlax-3D-point '(0.0 0.0 0.0)) 1.0 cTxt))
(vla-put-Height nTxt Hei)
(vla-put-Width nTxt(+ Wid(/ Hei 2)))
(vla-put-BackgroundFill nTxt -1)
(setq oDxf(entget(vlax-vla-object->ename nTxt))
      nDxf(subst (cons 45 Mask)(assoc 45 oDxf)oDxf)
       ); end setq
 (entmod nDxf)
 (vla-getBoundingBox nTxt 'mPt 'xPt)
 (setq mPt(vlax-safearray->list mPt)
       xPt(vlax-safearray->list xPt)
       mPt(vlax-3d-point
	      (list(+(car mPt)(/(-(car xPt)(car mPt))2))
		 (+(cadr mPt)(/(-(cadr xPt)(cadr mPt))2))
			 0.0))
		); end setq
         (vla-Move nTxt mPt(vlax-3D-point Pt))
  (if(and(> Ang 0)(<= Ang pi))
     (vla-Rotate nTxt(vlax-3D-point Pt)(- Ang(/ pi 2)))
     (vla-Rotate nTxt(vlax-3D-point Pt)(+ Ang(/ pi 2)))
   ); end if
    (if lFlg
       (vla-put-Lock cLay :vlax-true)
     ); end if
  nTxt
 ); end of Add_Masked_MText
 (if(not lab:Size)(setq lab:Size(getvar "TEXTSIZE")))
 (setq oldSize lab:Size
lab:Size
   (getreal
     (strcat "\nText size <"(rtos lab:Size)">: ")))
 (if(null lab:Size)(setq lab:Size oldSize))
 (princ "\n<<< Select lines and curves to label >>> ")
 (if(setq lSet(ssget '((0 . "*LINE,ARC,ELLIPSE,CIRCLE"))))
     (setq aDoc(vla-get-ActiveDocument(vlax-get-acad-object)))
     (vla-StartUndoMark aDoc)
     (foreach l(vl-remove-if 'listp(mapcar 'cadr(ssnamex lSet)))
(setq sPar(vlax-curve-getStartParam l)
	     ePar(vlax-curve-getEndParam l)
	     eLen(-(vlax-curve-getDistAtParam l ePar)
		      (vlax-curve-getDistAtParam l sPar))
             lPnt(vlax-curve-getPointAtDist l(/ eLen 2))
             iDr(vlax-curve-getFirstDeriv l
		  (vlax-curve-getParamAtPoint l lPnt))
	     iAng(- pi
		    (atan
		      (/(car iDr)
			(if(= 0.0(cadr iDr))(* 2 pi)(cadr iDr)))))
             cTxt(strcat(rtos eLen 2 0)"'")
             tWid(caadr
		   (textbox
		      (list(cons 1 cTxt)
			 (cons 40 lab:Size)(cons 41 0.)))
	     ); end setq
(Add_Masked_MText cTxt lPnt lab:Size (+ tWid(/ lab:Size 3)) 0.8 iAng 1.0)
); end foreach
       (vla-EndUndoMark aDoc)
     ); end progn
   (princ "\n<!> Nothing selected <!> ")
   ); end if
 ); end of c:lmark
Edited by Smirnoff
UNDO start and end marks was added
I made a routine to for the OP , but when I saw the codes that provided by Mr. Smirnoff , I felt shy to post them because
of the great routine that already given by him.
Great work Mr Smirnoff.
Appreciated.
... great routine that already given by him.
I think that you should not hesitate to submit your code to the forum. The more you write the code so the code will be better.
Thanks for the encouragement .:)
So comments are welcome anytime .
(defun c:Lentxt (/ ss)
 (if (setq ss (ssget "_:L" '((0 . "LINE"))))
    (lambda (i / ss1 e dis pt1 pt2 pt3)
      (while
       (setq ss1 (ssname ss (setq i (1+ i))))
         (setq e (entget ss1 ))
      (setq dis (distance (setq pt1 (cdr (assoc 10 e)))(setq pt2 (cdr (assoc 11 e)))))
      (cond ((< (car pt1)(car pt2))
         (setq pt3 (polar pt1 (setq ang (angle pt1 pt2)) (/ dis 2.)))
        ((> (car pt1)(car pt2))(setq pt3 (polar pt2 (setq ang (angle pt2 pt1)) (/ dis 2.)))
        (entmakex (list (cons 0 "TEXT")
              (cons 10 (polar pt3 ang 0))
                 (cons 1 (rtos dis 2))
               (cons 50 ang)
                     (cons 40 (getvar 'textsize))))
    -1
 (princ "\n No Line(s) selected")
Thanks.
Tharwat
Edited by Tharwat
Angular added to texts
  • Agree 1
Thank you both for the help.
Smirnoff
your code gave me this error
; error: no function definition: VLA-PUT-BACKGROUNDFILL
Please specify version and product name you use in your profile. It allow us to know what functions we can use for you what can't. Is your AutoCAD earlier than 2005 when background mask for text feature appear?
I just add ADJUSTMENTS section in my code. It allow more wide usage of this routine. Now you can adjust precision of measurement, suffix after measurement digits and use or don't use background mask for text. Now background mask is OFF.
       Precision Suffix BackMask)
[color="#0000ff"]  ; *****************************************************************************
 ;                                  ADJUSTMENTS                                ;
 ;                 (Modify it to adjust for your own requirements)              ;
 (setq Precision 0) 	; - precision of measurement (digits after decimal point)
 (setq Suffix "'")	; - Suffix after measirement for ex. "'" or "" for none
 (setq BackMask nil)   ; - Background mask borders from 1.0 to 10.0
 			;   or nil for none. Recomended value 1.0.
 			;   !!! nil for versions ealer AutoCAD 2005 !!!
  ; ******************************* END ADJUSTMENTS *****************************[/color]
 (vl-load-com)
   ); end setq
   (if(= 1 aSp)
     ); end if
     (setq lFlg T)
   ); end progn
); end if
    (if(= 1.0 wiF)
); end if
     (if Mask
       ); end setq
 (entmod nDxf)
 ); end progn
); end if
       mPt(vlax-3d-point
			 0.0))
		); end setq
   ); end if
    (if lFlg
     ); end if
  nTxt
lab:Size
   (getreal
	     iAng(- pi
		    (atan
		      (/(car iDr)
             cTxt(strcat(rtos eLen 2 Precision)Suffix)
             tWid(caadr
		   (textbox
		      (list(cons 1 cTxt)
	     ); end setq
(Add_Masked_MText cTxt lPnt lab:Size (+ tWid(/ lab:Size 3)) 0.8 iAng BackMask)
); end foreach
     ); end progn
   ); end if
 ); end of c:lmark
Have a nice day.
Layer and layer color to put labels added.
(defun c:lmark(/ aDoc cTxt eLen ePar iAng iDr lPnt lSet oldSize sPar tWid lCol
         cLay nTxt Precision Suffix BackMask Layer Color)
[color="#800080"] ; *****************************************************************************
 ;                                  ADJUSTMENTS                                ;
 (setq Suffix "")		; - Suffix after measirement for ex. "'" or "" for none
 (setq BackMask 1.0)   	; - Background mask borders from 1.0 to 10.0
 				;   or nil for none. Reocomended value 1.0.
 (setq Layer "s-tech-jlen") 	; - layer of markers or nil for current layer
 (setq Color 1)		; - color of layer for ex. 1 (Red)
 (vl-load-com)
   ); end setq
   (if(= 1 aSp)
     ); end if
     (setq lFlg T)
   ); end progn
); end if
    (if(= 1.0 wiF)
); end if
     (if Mask
       ); end setq
 (entmod nDxf)
 ); end progn
); end if
       mPt(vlax-3d-point
			 0.0))
		); end setq
   ); end if
    (if lFlg
     ); end if
  nTxt
lab:Size
   (getreal
    lCol(vla-get-Layers aDoc)
    ); end setq
     (if Layer
(if(vl-catch-all-error-p
     (vl-catch-all-apply
       'vla-Item(list lCol Layer)))
      (setq cLay(vla-Add lCol Layer))
      (vla-put-Color cLay Color)
      ); end progn
  ); end if
); end if
	     iAng(- pi
		    (atan
		      (/(car iDr)
             tWid(caadr
		   (textbox
		      (list(cons 1 cTxt)
	     ); end setq
(setq nTxt(Add_Masked_MText cTxt lPnt lab:Size (+ tWid(/ lab:Size 3)) 0.8 iAng BackMask))
(if Layer
   (vla-put-Layer nTxt Layer)
  ); end if
); end foreach
     ); end progn
   ); end if
 ); end of c:lmark
Edited by Smirnoff
grammar mistake
Thank you. I knew it was my 2002 version. I was going to try it at work on 2011. Thanks again for the help. And next time i will give all the info when asking for help.
  • 1 year later...
Hello I am new to the site and fairly new to lisp. I loaded and ran the above lisp posted by Smirnoff. When I select a line that is 70" it labels it as ";70
The lisp is clearly working but I need some help with the formatting. Also I was wondering if it is possible to label the line by rounding to the nearest foot? That is to say if I selected the same line that is 70" it would simply label it with a 6
Thanks for you help.
JB
Not sure about how to round imperic, try this out
 ;                                  ADJUSTMENTS                                ;
 (vl-load-com)
 ;; by Ian Bryant
(defun round (num)
                               (if (minusp num)
                               (* 2 (fix (- (/ num 2.0) 0.5)))
                               (* 2 (fix (+ (/ num 2.0) 0.5)))
   ); end setq
   (if(= 1 aSp)
     ); end if
     (setq lFlg T)
   ); end progn
); end if
    (if(= 1.0 wiF)
 (setq cTxt(strcat "[url="file://\\pxqc"]\\pxqc[/url];" Str))
 (setq cTxt(strcat "[url="file://\\pxqc{\\W"]\\pxqc{\\W[/url]" (rtos wiF) ";" Str "}"))
); end if
     (if Mask
       ); end setq
 (entmod nDxf)
 ); end progn
); end if
       mPt(vlax-3d-point
    0.0))
  ); end setq
   ); end if
    (if lFlg
     ); end if
  nTxt
lab:Size
   (getreal
    ); end setq
     (if Layer
     (vl-catch-all-apply
      ); end progn
  ); end if
); end if
     (foreach curve(vl-remove-if 'listp(mapcar 'cadr(ssnamex lSet)))
(setq sPar(vlax-curve-getStartParam curve)
      ePar(vlax-curve-getEndParam curve)
      eLen(-(vlax-curve-getDistAtParam curve ePar)
        (vlax-curve-getDistAtParam curve sPar))
             lPnt(vlax-curve-getPointAtDist curve(/ eLen 2))
             iDr(vlax-curve-getFirstDeriv curve
    (vlax-curve-getParamAtPoint curve lPnt))
      iAng(- pi
      (atan
        (/(car iDr)
             ;;cTxt(strcat(rtos eLen 2 Precision)Suffix)
             ;; cTxt(strcat(rtos eLen 4 0);|Suffix|;;******************************
            cTxt(rtos (round eLen) 4 0)
             tWid(caadr
     (textbox
        (list(cons 1 cTxt)
      ); end setq
(if Layer
  ); end if
); end foreach
     ); end progn
   ); end if
 ); end of c:lmark
~'J'~
Fixo, first off I would like to thank you for your assistance. Your knowledge and willingness to lend a hand is much appreciated.
I downloaded your revised lisp, it seems that it is now labeling the lines in feet and inches. The 70" line is now labeled as 5'-10"
Any chance this could follow the logic of Smirnoff's previous lisp where it reported in a decimal form and then the user could choose how many digits after decimal were reported but in feet instead of inches?
I was just thinking that since Smirnoff's lisp could label a line that was 5-1/2" as 6 (5.5 but rounded to 6 when the precision was set to 0) that maybe it could be modified to do the same thing with feet so it could label the 70" line as 5.83 and then round to 6 with a precision of 0.
Thanks again.
JB
I will finish this part of feet rounding, but been busy right know
See you later, sorry
~'J'~
How about this code?
 ;                                  ADJUSTMENTS                                ;
 (vl-load-com)
 ;; by Ian Bryant
(defun round (num)
                               (if (minusp num)
   ); end setq
   (if(= 1 aSp)
     ); end if
     (setq lFlg T)
   ); end progn
); end if
    (if(= 1.0 wiF)
); end if
     (if Mask
       ); end setq
 (entmod nDxf)
 ); end progn
); end if
       mPt(vlax-3d-point
    0.0))
  ); end setq
   ); end if
    (if lFlg
     ); end if
  nTxt
lab:Size
   (getreal
    ); end setq
     (if Layer
     (vl-catch-all-apply
      ); end progn
  ); end if
); end if
      iAng(- pi
      (atan
        (/(car iDr)
            cTxt (rtos (cvunit (round eLen) "in" "inch")2 0)
             tWid(caadr
     (textbox
        (list(cons 1 cTxt)
      ); end setq
(setq nTxt(Add_Masked_MText cTxt lPnt lab:Size (+ tWid(/ lab:Size 3)) 1.0 iAng BackMask))
(if Layer
  ); end if
); end foreach
     ); end progn
   ); end if
 ); end of
Fixo, thank you for the timely response. I will test this tomorrow when I have access to CAD, and let you know.
Thanks,
JB
Good day Fixo,
I tested your provided code, it was labeling in inches. So I made one small change to it.
I changed:
To:
cTxt (rtos (cvunit (round eLen) "in" "feet")2 0)
It is now labeling the lines in feet. I was not clear in my previously request, but I was hoping to have it always round up to the next foot instead of the nearest foot. Do you know how to make it round up so 14'-0" = 14, but 14'-1" = 15? Sorry for not communicating this previously.
Thanks
JB
Hi , JB
I will look at this later,
~'J'~
