Lee Mac Posted September 25, 2008 Posted September 25, 2008 Hi guys, I've been working on a LISP to create instrument and nozzle tags (basically a line with a circle attached to it and some text within the circle). I have created a separate program that the user may invoke to set some "base variables" ie. circle radius, text height. However, I have encountering some errors when running this separate program. I cannot see what is wrong as I have used code in the same format in other LISPs that I have created. I would appreciate any help available. Thanks Lee tktag2.lspFetching info... Quote
VovKa Posted September 25, 2008 Posted September 25, 2008 you've made two spelling errors in these two expressions (getenv "tag:tcirc") (setenv "tag:tcirc" (rtos tcircr)) i suspect it should be "tag:tcircr" Quote
Lee Mac Posted September 26, 2008 Author Posted September 26, 2008 Thanks Vovka, That solved the problem - I knew it would be something stupid like that! Quote
