kayaan Posted January 23, 2011 Posted January 23, 2011 Hi friends,is it possible to make 3d contour by using coordinates like x,y,z.that means if i putting value of xyz can i made 3d contour.thanks in adv. Quote
Tyke Posted January 23, 2011 Posted January 23, 2011 All contours by definition are 2D, but with a constant elevation. If you input a set of points all with the same Z value the line produced could be described as a contour. If your points have different Z values you need to either input them into a program that can produce contours or you need to interpolate them yourself. Quote
eldon Posted January 23, 2011 Posted January 23, 2011 If you make the contour by drawing an ordinary polyline (not a 3D polyline), then at the first point you enter x, y and z, but for all the next points, you only enter x and y. The z value stays the same throughout the polyline. Quote
kayaan Posted January 23, 2011 Author Posted January 23, 2011 eldon said: If you make the contour by drawing an ordinary polyline (not a 3D polyline), then at the first point you enter x, y and z, but for all the next points, you only enter x and y. The z value stays the same throughout the polyline. thanks,i understand little bit i will try. Quote
