I am using ADT2006. A co-worker of my really likes the LE command. Is there a way that i can get a leader (when using the LE command) to come in on the A-Anno-Dims layer instead of the current layer, without having to set the current layer to A-Anno-Dims?
Thanks in Advance.
I'd program a button to do it, but you'd probably be better off asking somebody to write you a lisp on the lisp part of the forum :thumbsup:
  • 3 weeks later...
I have also noticed that in some drawings the leader does not scale (at all), but it does scale in other drawings. What could be causing this?
you can create a tool for your palette that forces the object on a layer. or you can change your layer key to do this as well.
The drawings are on the correct layer key and it looks like I am going to have to slowly steer them to the ways of the tool palette. The problem is they have been drafting a long time and it is hard to get them to change their ways. Thanks for all the help.
I used to be one of the hardcore typing folk. I love the palettes now, and do things in a sort of hybrid way.
