Plot file grows - LARGE!
Hello everyone. I have just signed up to CADTutor but am not new to it as I occasionally research topics on it.
I have AutoCAD 2010 and AutoCAD 2000i LT. I don't know why, but I still prefer 2000 LT for my purposes. My problem, then, is with plotting in LT 2000i.
I have a 300 kb file. I am plotting a portion of the file, maybe 65 kb worth. However, when I send it to plot it takes forever to load into the plotter. I pulled up the Printer Queue window and saw that the plot file is 17.7 Mb. The job is slowly loading in. This has happened on two other similar files.
Again, I'm running ACAD LT 2000i in Windows XP. I'm sending the plot to a HP 750C Plus plotter with added memory.
Thanks.
Yes, I've even reduced the number of layers. It has about 10 in it. Purged everything else, too. Just started plotting, it took 35 minutes for it to load in.
Have you tried the old trick of closing everything and rebooting your computer and then restarting AutoCAD and trying to plot?
Yes, I have shutdown all applications, the computer and the plotter. None of it worked.
Some of the other files have no problem plotting, the don't "grow", load right in and the plotter takes off. I've compared all plot parameters, settings, etc between the files and see no difference.
Open the drawing in AutoCAD 2010. Audit it. Save it. Plot it.
Are you using TrueType fonts?
2000i? Second one today. Did you ever install any service packs?
Well, opening it to 2010 and Auditing it seemed to help quite a bit. It's still a bit large, 990 kb, but that's much better than 17 Mb. Thanks for your help.
Now that you have the drawing in 2010 leave it there. If you try to save it down to 2000 file format expect the drawing file size to balloon again. I would seriously think about retiring 2000i. Consider this the "push" that you needed.
