Arvid93 Posted January 15, 2011 Share Posted January 15, 2011 I try to loft (solid) a couple of circles with varying diameter and when I choose the guides (red) it tells me "The selected entities are not valid.". I cant understand why it doesn't work. Anyone wanna take a look at it? Lofting.dwg Quote Link to comment Share on other sites More sharing options...
kencaz Posted January 15, 2011 Share Posted January 15, 2011 Try lofting circles not surfaces and you should only need the yellow line and use the "path" option during your loft. KC Quote Link to comment Share on other sites More sharing options...
fahim108 Posted January 16, 2011 Share Posted January 16, 2011 Or you may SWEEP your circle to that polyline path, then use the "Scale along path" option (from the solid's property flag) to get a smoother result. Quote Link to comment Share on other sites More sharing options...
Arvid93 Posted January 16, 2011 Author Share Posted January 16, 2011 Try lofting circles not surfaces and you should only need the yellow line and use the "path" option during your loft. KC That worked pretty well, but it was not exactly along the guidelines, but thanks anyway! Quote Link to comment Share on other sites More sharing options...
Arvid93 Posted January 16, 2011 Author Share Posted January 16, 2011 Or you may SWEEP your circle to that polyline path, then use the "Scale along path" option (from the solid's property flag) to get a smoother result. That worked excellent, Thanks alot! Quote Link to comment Share on other sites More sharing options...
