Updated to Version 1.2 to include UCS/Views and also a handy Search Bar :)
  • Replies 46
  • Lee Mac
    25
  • Jack_O'neill
    3
  • Tharwat
    3
  • Lee Roy
    3
Updated to Version 1.3
This should correct an issue with nested blocks and also allow the user to import Layer States. :)
Enjoy!
Lee
  • 7 months later...
I have updated this program to Version 1.5
This version implements a number of changes to improve the program:
  • Added the ability to use Wildcard Patterns in the 'ItemList' parameter to allow all items in a collection which match the supplied wildcard pattern to be imported.
  • Added Materials and Named Viewports to the list of collections.
  • Added 'StealAll' command to allow the user to automatically steal everything from a selected drawing file.
  • Added 'StealTemplate' command to enable the user to quickly steal items from the QNew template file (or other template file, if the QNew template file is not set).
The latest version can be found here.
You never cease to amaze us Lee. Thanks for your tireless efforts.
I've run into an issue, I get "Error: Automation Error. Problem in loading application". =/
What product are you running this on Lee Roy?
AutoCAD MEP 2012
Did I miss somewhere that says it won't work? If I did, my bad. :facepalm:
-Edit- I see where you said you're a vanilla guy. I'll try it on vanilla.
-Edit- Same response/error in vanilla AutoCAD 2012.
Edited by Lee Roy
That's weird since this is the first I've heard of an error report of this nature (for any version in fact). From the error message you posted I'm guessing the program cannot load the ObjectDBX Document.
Does this return a non-nil value:
(vl-registry-read (strcat "HKEY_CLASSES_ROOT\\ObjectDBX.AxDbDocument." (itoa (atoi (getvar 'ACADVER))) "\\CLSID"))
Is anyone else having this problem?
It works very nice here .
Thanks for the efforts Lee.
Thanks for testing it Tharwat :)
It returns "nil".
Anxious to get this working, as I'd like to use it. I'll bet it's something on my end. :glare:
-Edit- I see what you're looking for. For some reason, a while back, I had pulled the registry value trying to accomplish something I don't remember what now. I had the registry value backed up on my desktop. I just now merged it back in and the command works great.
Thanks Lee!
Sorry for the waste of time. :facepalm:
Awsome tool Lee. Thx a lot m8:D
SB
  • 3 weeks later...
Hi Lee,
Great lisp, is it possible to use this to steal the layers and also bring everything draw in the layers?
Cheers
  Designer said:
Hi Lee,
Unfortunately not.
  • 4 weeks later...
Lee, I enthusiastically love your language and grammar in writing codes.
I appreciate as always your efforts resulting very useful "Steal" ...
...For now I have a question:
Is it possible to have a function to do "Steal" silently and without dialogs?
Thank you Ahankhah :)
Certainly, have a read of the description on my website, I also include examples to demonstrate :)
Lee,
Thank you for your reply.
I tried it with "*" wildcards with no success. It seems I must study deeply in your code.
I am going to read your nice code more carefully.
