jaswindersingh Posted June 23, 2020 Posted June 23, 2020 Hi Lee, the Lisp used to work fine for me but recently i started getting this error "Sample not found in first column of CSV file." I am using Civil 3d 2019. thanks in advance. Quote
Steven P Posted June 23, 2020 Posted June 23, 2020 I assume you read through the comments on the last page and none of them worked? (just checking with a silly question) Quote
jaswindersingh Posted June 25, 2020 Posted June 25, 2020 Yes tried everything ... but still getting that same error Quote
Lee Mac Posted June 26, 2020 Author Posted June 26, 2020 Does your CSV file use a different delimiter to that used by your system regional settings? Try opening the CSV file in a plain text editor (such as Windows Notepad), and replacing the commas with semi-colons. 1 Quote
Chris Dougall Posted December 8, 2020 Posted December 8, 2020 Hi Lee,I'm having the exact same issue as a user has mentioned above - "{drawingname} not found in first column of CSV file." This has begun occurring out of nowhere, across all of the dirctories that this lisp is utilized. I've tried updating the the latest version of your UTB .lisp with no difference. I dont have other add ons and this has begun occurring out of nowhere. Error code details below; ; error: bad argument type: stringp nil :: UpdateTitleblock.lsp | Version 1.9 | © Lee Mac 2020 www.lee-mac.com :: :: Type "utb" to run manually :: 715-EL-MCC-0004_7 not found in first column of CSV file. Checking the .csv file reveals that that drawing name is definitely in the first column, I've tried with and without the .dwg extension - no difference. The .csv works exactly the same as before, with commas and not semi-colons. Any ideas on what i can try next ? Kind regards, Chris Quote
Lee Mac Posted December 9, 2020 Author Posted December 9, 2020 Are you testing using the program exactly as it appears on my site, or have you modified it at all? I ask because you should not be receiving this error message: ; error: bad argument type: stringp nil 1 Quote
Chris Dougall Posted December 10, 2020 Posted December 10, 2020 On 12/9/2020 at 1:30 PM, Lee Mac said: Are you testing using the program exactly as it appears on my site, or have you modified it at all? I ask because you should not be receiving this error message: ; error: bad argument type: stringp nil Exactly as appears on site, i've tried again without any csv filename designated also with the same result. Quote
Lee Mac Posted December 12, 2020 Author Posted December 12, 2020 Are you able to upload a sample CSV file? 1 Quote
Chris Dougall Posted December 13, 2020 Posted December 13, 2020 Sure Lee, please see attached. TITLEBLOCKDATA.csvFetching info... Quote
Lee Mac Posted December 13, 2020 Author Posted December 13, 2020 Thanks - could you please run the attached debug version and report back the command line history? UTB_Debug.lspFetching info... 1 Quote
Chris Dougall Posted December 13, 2020 Posted December 13, 2020 Thanks Lee, please find attached. UTB_DEBUG.txtFetching info... Quote
Lee Mac Posted December 13, 2020 Author Posted December 13, 2020 Thanks Chris - it looks like the debug program has run successfully (reporting "All attributes are up-to-date.") - are you sure you're testing the main program exactly as it appears on my site, as I'm perplexed as to why the debug program ran successfully when it is merely printing additional messages to the command line. 1 Quote
Chris Dougall Posted December 14, 2020 Posted December 14, 2020 Lee, awesome - I think we're close. When using the debug and manually denoting the csv file location as prompted it discovers the correct one. But when I specify in the .lisp routine to search the same directory as the drawing for a titleblockdata.csv - It discovers an incorrect csv file that is in a different directory ( but has been previously utilized ). Can you think of a reason that the .lisp routine might bypass the .csv file that is in the 'same as drawing' directory and instead utilize one from a different folder ?UTB_Debug.lsp Attaching the .lisp with the updated csv path for reference, as well as the new debug code ( showing that it's picking up a different .csv than before ) UTB_DEBUG_Discovering wrong csv.txtFetching info... Quote
Lee Mac Posted December 14, 2020 Author Posted December 14, 2020 On 12/14/2020 at 12:17 AM, Chris Dougall said: When using the debug and manually denoting the csv file location as prompted it discovers the correct one. But when I specify in the .lisp routine to search the same directory as the drawing for a titleblockdata.csv - It discovers an incorrect csv file that is in a different directory ( but has been previously utilized ). Can you think of a reason that the .lisp routine might bypass the .csv file that is in the 'same as drawing' directory and instead utilize one from a different folder? What is returned when you enter the following at the command line? (findfile "TITLEBLOCKDATA.csv") Does the erroneous file reside in an AutoCAD Support Path? 1 Quote
Chris Dougall Posted December 14, 2020 Posted December 14, 2020 Lee, based on the findfile command you gave and comparing to support filepaths we've worked it out. It was a support path pointing to a OneDrive mydocuments directory, that within subfolders had another "titleblockdata.csv". My company rolled IT updates on our machines without me knowing and it added this onedrive support file path. Thanks very much for your help on this, you're a champion. Love your work. Kind regards, Quote
Lee Mac Posted December 14, 2020 Author Posted December 14, 2020 You're most welcome Chris - I'm glad you were able to pinpoint the issue! 1 Quote
Will_123 Posted March 22, 2021 Posted March 22, 2021 Hi, Is Update Titleblock Attributes possibly available as .scr, NOT lisp? Is it possible to have Update Titleblock Attributes as script that would update tags from .csv file from folder where drawings or .csv files live, without any prompts? I would like to run this script on another program, to change plenty of tags on multiple drawings, that I manage via excel spreadsheet. Lee, I think lots of your fans would also like such option. Regards, Will Quote
Lee Mac Posted March 22, 2021 Author Posted March 22, 2021 (edited) On 3/22/2021 at 3:41 PM, Will_123 said: Is Update Titleblock Attributes possibly available as .scr, NOT lisp? Is it possible to have Update Titleblock Attributes as script that would update tags from .csv file from folder where drawings or .csv files live, without any prompts? I would like to run this script on another program, to change plenty of tags on multiple drawings, that I manage via excel spreadsheet. Lee, I think lots of your fans would also like such option. This is already possible with the current version of the application - simply configure the utb:csv parameter (line 126) to point to the CSV file from which attribute values should be sourced (this may reside at an absolute or relative filepath, or within the working directory of the drawings being modified), and then load & run the program across multiple drawings using a basic AutoCAD Script configured to open each drawing, load & run the UTB program, and then save & close the drawing - you could even use my Script Writer application to generate & run such a script automatically. Edited March 22, 2021 by Lee Mac Quote
LISPnoob Posted March 21, 2024 Posted March 21, 2024 Hello! First off, thank you Lee for creating the lisps. You are truly a hero. Not to mention, the instructions are generally easy to follow as well for a noob like me. Anyhow- I am currently working on a project where I have to update the attributes of ~200 drawings. I tried to use the latest version of the UpdateTitleblock lisp, and it seems to run just fine, but it doesn't update my attributes. The command line, though, says that "Attributes are up to date". In this case, I'm not too sure why it's not working. Everything else seems to be set up fine. Does anyone know why this might be happening? I am using ACAD LT 2024. The only other available ACAD software that I can probably download here at work is ACAD Map 3D 2024. Thanks in advance to anyone who responds! Quote
Kkross Posted July 11, 2024 Posted July 11, 2024 Hello Lee! I have the same issue as LISPnoob, the command says Attributes are up to date but nothing is updated, I am using the model from your web and nothing has been changed. Quote
