As posted over at theSwamp, I thought I'd post it here for you guys also :)
CopyText.lsp
The program will allow a user to copy the text content from a source object to a selection of destination objects or swap the text content between two objects. The user may select from Text, MText, Attribute, or Multileader objects.
Upon choosing 'Settings' the user can alter whether source object formatting should be retained upon copying/swapping to/with objects which permit the use of such formatting.
Ideas/criticism/feedback are, as always, welcome :)
Enjoy!
Lee
CopySwapTextV1-6.lspUnavailable
Edited by Lee Mac
  • 4 years later...
I have completely rewritten this program to fix a number of bugs present in the previous version.
The new version may be downloaded from my site here, or from the first post of this thread.
Enjoy!
Lee
Lee
Nice work as always.
Curios , How were you able to apply Color to Attributes? Multi-line or otherwise.
pBe
  pBe said:
Lee
Thanks pBe :)
The red & cyan colours were obtained using MText formatting codes applied to Multiline Attributes - or were you referring to something else?
You are correct. Never did try to change the color of Multi-line Attributes manually, so i figured it cannot be done with lisp codes. But you sure showed me its doable :thumbsup: Cant say the same for regular attributes though
Thanks a mil LM :)
So no more double-clicking, ctrl+c, escape, double clicking, ctrl+v, escape? But that was SO much fun! Ha ha ha! Thanks Lee!
Nicely done.
Thank you Lee!
Henrique
You can count on me to spoil your fun ;) :lol:
Enjoy resullins :)
  • 1 year later...
  yohsuryak said:
doesn't work at autocad2015 lee :(
Why you dont post your error message ^^ ?
Mine is working fine in 2015, so it might be a system setting. Also, Lee do you think it would be easy to do a check if the source and destination object is a dimension, and if so, allow it to copy it. Maybe something like this (this is part of my copy dimension program)?
(if (setq ss (LM:ssget "\nSelect destination dimensions:"
                                  '(((0 . "DIMENSION")))
               (setq obj (vlax-ename->vla-object ent)
                     cnt 0
               (repeat (sslength ss)
                 (setq obj2 (vlax-ename->vla-object (ssname ss cnt)))
                 (vla-put-TextOverride obj2 (vla-get-TextOverride obj))
                 (setq cnt (+ cnt 1))
           (setq whilestop nil)
Why would you override your dimensions? it already allows you to copy a source dimension.
I have to override dimensions all the time. Many of my dimension have TYP., MIN., ESMT., after them. It kind of stinks to have to edit the text every time which is why I made my own routine so that I only have to do it once.
Many thanks for the feedback!
I have now updated this program to Version 1.5 to incorporate compatibility with Dimensions & MLeader Block Attributes.
Thank you very,very much sir. you have saved our lot of time for our all users.
Lee, thank you so much for this update, it is super useful and saves a ton of time. Do you happen to know why when I run it and copy from one dimension to another, I get Error: bad argument type: stringp nil and then it exits the while loop? It still will copy from one dimension to another, but you can only do it once.
You're welcome - I'm delighted that you both find the program so useful!
After some testing, I can't seem to reproduce this error - are you able to upload an example drawing for which the program fails and describe the steps necessary to reproduce the error?
