e.mounir Posted January 5, 2011 Posted January 5, 2011 Hi all I have a lot of Mtext and I need change the Width factor for all text anyone have lisp idea hot to change it . Quote
designerstuart Posted January 5, 2011 Posted January 5, 2011 possible workaround would be to create a new style or alter the text style as you can specify width factor in styles. sorry - not a lisp - but you posted in beginner's area ;-) Quote
Tiger Posted January 5, 2011 Posted January 5, 2011 QSELECT to get all the MTexts selected and then change the Width in Properties? Quote
designerstuart Posted January 5, 2011 Posted January 5, 2011 you can't change width factor in properties, can you? Quote
Tiger Posted January 5, 2011 Posted January 5, 2011 you can't change width factor in properties, can you? Gosh dang it again! No you can't, you're right. I was thinking of width of the text not the width factor in the text. Quote
ReMark Posted January 5, 2011 Posted January 5, 2011 What am I missing here? Isn't the Width Factor an option that can be changed in the Style dialog box? Quote
Tiger Posted January 5, 2011 Posted January 5, 2011 What am I missing here? Isn't the Width Factor an option that can be changed in the Style dialog box? Yep, that is what it sounds like the OP is after. We'll see if he comes back and confirms it. Quote
ReMark Posted January 5, 2011 Posted January 5, 2011 If that were the case (meaning that's what the OP is talking about) then changing the Width Factor in the Text Style dialog box should globally change it for all the text (including MText) in the drawing of that particular style. Quote
condfitz Posted January 27, 2021 Posted January 27, 2021 Sorry Late to the Party Explode all Mtext. Highlight all text. Go to properties then change width factor to desired. Using Express tool Convert all text back to Mtext. (Settings -combine into a single Mtext object-) Done. Quote
