hey guys I am looking for a way to convert 2D polylines to 3D polylines containing Arcs, or just the ability to convert to Arcs to Polylines so I can convert them to 3D polylines!!!
Crazy arcs!
Thanks :D
all that does is "mask" in sense the arc, while it does convert it to a polyline it is still an arc if exploded, which is what is giving me problems, I need to convert a bunch of center-lines containing arcs from 2D to 3D, the problem is that the 2D poly lines containing arcs will not convert.
thanks
*edit*
This was a reply to a post (which was deleted) that suggested to use pedit or mpedit to convert the arc into a 2D poly
Hi, sorry I deleted that post :D I misunderstood the question.
does FLATTEN also now work?
  • 13 years later...
how to convert 2d polyline to 3d polyline with arcs?
Depending on accuracy required you can make arcs into short facets which can be made into 3dpoly.
