JBullseye74 Posted March 14, 2006 Share Posted March 14, 2006 Does anyone have OR know of where i can get my grimy fingers onto a load of blocks of column and beams..? Would really come in handy as i've got a load of steelwork drawings to do and will save me drawing them up from scratch. If there has been something posted before regarding the above then i apologise but i haven't had time to look.. Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 14, 2006 Share Posted March 14, 2006 One source: http://www.cadtoolsonline.com/blocks.htm Here's another: http://www.southforktech.com/shapebook.htm One for metric steel shapes (and it's a freebie): http://www.freecadapps.com/swdetails.php?page=category&value=ACC-HDW&orgvalue=ACC&review=2832&rowcolor=fce08d Another: http://www.aay.com/steelwks.htm If these aren't exactly what you're looking for then "Google" the following: "steel shapes"+"autocad" Include the quotation marks and the + sign in your search criteria. Quote Link to comment Share on other sites More sharing options...
JBullseye74 Posted March 14, 2006 Author Share Posted March 14, 2006 Cheers ReMark... i owe you one. If that ever possible :-) Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 14, 2006 Share Posted March 14, 2006 Cheers ReMark... i owe you one. If that ever possible :-) You're entirely welcomed. And, I'll hold you to that...someday. Cheers! Quote Link to comment Share on other sites More sharing options...
good_m Posted March 14, 2006 Share Posted March 14, 2006 Jimmy, Here's a lisp routine that works great...go to http://mgoodarch.com/Lisp%20Routine.htm and download Steel.rar. It has a dialoge box where you can choose what time of structural member that you want to use (ie. HSS, angle, W shape etc.) and it has the individual sizes in it. Mike Quote Link to comment Share on other sites More sharing options...
JBullseye74 Posted March 14, 2006 Author Share Posted March 14, 2006 Thanks Good_m.. thats a nice one too, will put all to good use. :-) Quote Link to comment Share on other sites More sharing options...
nicespejo Posted January 19, 2009 Share Posted January 19, 2009 does anyone have any autocad details for joining 2 steel i beams in a T section as i dont know how to join them and i need to put the detail on my drawing any help would be much appreciated Quote Link to comment Share on other sites More sharing options...
A1DWG Posted January 19, 2009 Share Posted January 19, 2009 Hi, If you could answer which country you are in? - The reason is I'm sure that different countries have different standards / codes to work to, so an answer from the UK might not be OK for the USA. Anyway, to answer your question (from the UK) it is usual to do one of the following: 1) If both beams are the same size, then weld a plate / angle on the main beam parallel to the 2nd beam, and bolt this to the2nd (trimmed) beam. 2) If the trimmed beam is smaller and fits in the web of the main beam - weld an end plate and bolt it to the web of the main beam. I'll have a look for some details, but I would RECOMMEND you state "the beam sizes and connections are indicative only, and need designing by an Engineer". If not and someone builds to what you have drawn you are liable. I think there are a lot of resources available, Dimension for steel sections (UK - Corus blue book, and lots of CAD blocks) typical connection details / examples. Hope this helps. Quote Link to comment Share on other sites More sharing options...
stevsmith Posted January 26, 2009 Share Posted January 26, 2009 I have them at work p/m me and i will send them to your email Quote Link to comment Share on other sites More sharing options...
The cad guy Posted December 15, 2009 Share Posted December 15, 2009 Hi i got steelwork blocks from ebay, they can be loaded onto a pull down menu on the toolbar so easy to find. Best add on i bought http://cgi.ebay.co.uk/AUTOCAD-STEELWORK-SECTIONS-CAD-BLOCKS_W0QQitemZ250546142274QQcmdZViewItemQQptZUK_Computing_DesktopPCs?hash=item3a55b6bc42 Hope this helps Quote Link to comment Share on other sites More sharing options...
Vic_Poole Posted April 11, 2015 Share Posted April 11, 2015 A complete set of U.K. industry structural steel shapes is available at http://www.cad-steel.co.uk nicespejo - see the property pages - the header images show you how to connect steel beams together, giving you all the notch dimensions you need! Quote Link to comment Share on other sites More sharing options...
