As it can be seen in this image, the view is cutting through the walls and the sideguard, even if the camera still far from them. Is there any way to avoid this or do I have to migrate to another program to get proper views?
That doesn't seem to be the problem.
Sometimes it only happens after I navigate with the wheel. For example, I can look around and everything's normal, but after I release the mouse button the walls get clipped.
My experience with AutoCAD is also pretty bad - since 2008 version there are always problems and crashes. And the software is getting bigger and slower despite I upgraded my computer since then - where Rhino flies AutoCAD is duying badly. Today I have a blue screen - imported an 3ds file and when trying to convert the mesh to smoothed solid AutoCAD filled all the ram and quieted. Not to mention that the file was only 2mb - nothing fancy but selecting it in AutoCAD slowed the performance. The same file in Rhino was a breeze to work with.
Copy/paste this 3D model in a new blank drawing. See if you still get this error...
