Guest Posted November 12, 2013 Posted November 12, 2013 satishrajdev can you add a command to give the text size ,because all the times the text is 2.5 and is too big !! Quote
MSasu Posted November 12, 2013 Posted November 12, 2013 Check the GETREAL function and line below: (entmake (list (cons 0 "TEXT")(cons 10 (trans p3 1 0)) [color=magenta](cons 40 (getvar 'textsize))[/color] (cons 7 "TanLine") Quote
Guest Posted November 12, 2013 Posted November 12, 2013 I now few thing about lisp .Please help me litle more Quote
Guest Posted November 12, 2013 Posted November 12, 2013 (setq h (getdist "\nGive the text size:")) (entmake (list (cons 0 "TEXT")(cons 10 (trans p3 1 0)) (cons 40 (getvar 'textsize)) (cons 40 h) (cons 7 "TanLine") I try this but didn' t work ! Quote
satishrajdev Posted November 12, 2013 Posted November 12, 2013 TRY This :- (defun c:TanLine (/ doc spc *error* TH:UnDo TH:StartUnDo p1 p2 p3 p4 tan2 TL-Line TH:UnDo ) ;;; Authour : Hasan Asos -> Modified by Tharwat (vl-load-com) (command "-style" "TanLine" "wgsimpl.shx" 0 1 0 "N" "N") (and (setq doc (cond (doc) ((vla-get-ActiveDocument (vlax-get-Acad-Object))) ) ) (setq spc (if (zerop (vla-get-activespace doc)) (if (= (vla-get-mspace doc) :vlax-true) (vla-get-modelspace doc) (vla-get-paperspace doc) ) (vla-get-modelspace doc) ) ) ) (defun *error* (msg) (and TH:UnDo (vla-EndUndoMark doc)) (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*") (princ (strcat "\n** Error: " msg " **")) ) (princ) ) (setq TH:StartUnDo (vla-StartUndoMark doc)) (initget "Line Points") (if (eq (setq TL-sel (getkword (strcat "\nChoose [Line/Points]: " "< Line >")) ) "Points" ) (progn (setq p1 (getpoint "\n First Point ")) (setq p2 (getpoint p1 "\n Second Point ")) (setq p3 (getpoint "\n Text insertion Point ")) (setq p4 (getreal "\n Specify text height ")) (setq tan2 (/ (- (cadr p2) (cadr p1)) (- (car p2) (car p1)))) (entmake (list (cons 0 "LINE") (cons 10 (trans p1 1 0)) (cons 11 (trans p2 1 0)) ) ) (entmake (list (cons 0 "TEXT") (cons 10 (trans p3 1 0)) (cons 40 p4) (cons 7 "TanLine") (cons 1 (strcat (rtos (abs (* tan2 100)) 2 4) "%")) ) ) ) (progn (prompt "\n please Select Line : ") (setq TL-Line (ssget '((0 . "LINE")))) (setq e (ssname TL-Line 0)) (setq p1 (cdr (assoc 10 (entget e)))) (setq p2 (cdr (assoc 11 (entget e)))) (setq p3 (getpoint "\nText insertion Point ")) (setq p4 (getreal "\n Specify text height ")) (setq tan2 (/ (- (cadr p2) (cadr p1)) (- (car p2) (car p1)))) (entmake (list (cons 0 "TEXT") (cons 10 (trans p3 1 0)) (cons 40 p4) (cons 7 "TanLine") (cons 1 (strcat (rtos (abs (* tan2 100)) 2 4) "%")) ) ) ) ) (setq TH:UnDo (vla-EndUndoMark Doc)) (princ "\n Modified by Tharwat") (princ) ) Quote
MSasu Posted November 12, 2013 Posted November 12, 2013 Prodromosm: The DXF code 40 store the height of label - you forgot to remove the original one: (entmake (list (cons 0 "TEXT")(cons 10 (trans p3 1 0)) [color=red][s](cons 40 (getvar 'textsize))[/s][/color] (cons 40 h) (cons 7 "TanLine") Quote
satishrajdev Posted November 12, 2013 Posted November 12, 2013 PRODROMOSM.......... you need to know about functions, check here http://www.theswamp.org/~john/avlisp/ Quote
