jmerch Posted December 13, 2010 Posted December 13, 2010 I've searched what I could and can't find my answer. Is there a LISP function similar to "alert" but instead of just the pop-up box it let's the user input something there (instead of using "prompt" in LISP)? Quote
alanjt Posted December 13, 2010 Posted December 13, 2010 Roll your own with DCL/ODCL or check out DosLib, it has a few input 'alert' style boxes. Quote
Lee Mac Posted December 13, 2010 Posted December 13, 2010 Thought it'd be fun to write an example: (defun PromptBox ( title msg / dcl dch file val ) ;; ------------------------------------------- ;; ;; Arguments:- ;; ;; ------------------------------------------- ;; ;; title - Dialog Box Title ;; ;; msg - [Optional] Text to Display ;; ;; ------------------------------------------- ;; ;; Returns:- ;; ;; ------------------------------------------- ;; ;; Entered String if user presses OK, else nil ;; ;; ------------------------------------------- ;; ;; Example by Lee Mac 2010 - www.lee-mac.com ;; ;; ------------------------------------------- ;; (cond ( (not (and (setq dcl (vl-filename-mktemp nil nil ".dcl")) (setq file (open dcl "w")) (progn (write-line (strcat "promptbox : dialog { label = \"" title "\"; initial_focus = \"txt\"; spacer;" ": edit_box { key = \"txt\"; edit_width = 60; edit_limit = 2048; allow_accept = true; } spacer; ok_cancel; }" ) file ) (setq file (close file)) (findfile dcl) ) ) ) ) ( (<= (setq dch (load_dialog dcl)) 0) (vl-file-delete dcl) ) ( (not (new_dialog "promptbox" dch)) (unload_dialog dch) (vl-file-delete dcl) ) (t (if msg (setq val (set_tile "txt" msg))) (action_tile "txt" "(setq val $value)") (if (zerop (start_dialog)) (setq val nil)) (unload_dialog dch) (vl-file-delete dcl) ) ) val ) 1 Quote
jmerch Posted December 13, 2010 Author Posted December 13, 2010 @alanjt - Gotcha, will give that a try. Thanx. @lee - I can understand most of that but will disect it later. It looks like you're having LISP write the DCL which I think is very funny and cool. I did take a gander at AfraLISP's DCL beginner guide and may have what I need to get me going. But am still intrigued at your direction with this. Quote
Lee Mac Posted December 13, 2010 Posted December 13, 2010 @lee - I can understand most of that but will disect it later. It looks like you're having LISP write the DCL which I think is very funny and cool. I did take a gander at AfraLISP's DCL beginner guide and may have what I need to get me going. But am still intrigued at your direction with this. Yes, the DCL file is written to a temporary filename generated by vl-filename-mktemp, this file is then deleted following function completion. You can test it with something like: (PromptBox "Information" "AutoLISP is Fun") Or maybe: (PromptBox "Title" nil) Lee 1 Quote
jmerch Posted December 13, 2010 Author Posted December 13, 2010 Ok, will give those a try. Thanks! Quote
Lee Mac Posted December 13, 2010 Posted December 13, 2010 Ok, will give those a try. Thanks! You're very welcome JMerch - any questions about the code, just ask Quote
