chenfire7 Posted December 12, 2010 Share Posted December 12, 2010 in 2011, how can i cancel the snap on z direction so that my drowing will be only in 2d? Quote Link to comment Share on other sites More sharing options...
Cad64 Posted December 12, 2010 Share Posted December 12, 2010 Set your OSNAPZ variable to 1 and set your ELEVATION value to 0, or whatever elevation you want. If Osnapz is set to 0, Osnap uses the "X", "Y" and "Z" value of the snapped point. If Osnapz is set to 1, Osnap uses the "X" & "Y" location of the snapped point and the current value of the ELEVATION system variable. This allows you to snap to any line in your drawing, but whatever you draw will always stay at the same Z elevation. Quote Link to comment Share on other sites More sharing options...
