glazier Posted March 12, 2006 Share Posted March 12, 2006 Does anyone have a good 3d fastener Library of Bolts, Screws, nuts and the likes. Quote Link to comment Share on other sites More sharing options...
a_differently abled_draft Posted March 12, 2006 Share Posted March 12, 2006 i've been searching for the same; no success yet Quote Link to comment Share on other sites More sharing options...
glazier Posted March 17, 2006 Author Share Posted March 17, 2006 I have found a very good fastener library it has 2d and 3d in about every thing you could need. http://www.mcmaster.com Quote Link to comment Share on other sites More sharing options...
Adesu Posted March 21, 2006 Share Posted March 21, 2006 Does anyone have a good 3d fastener Library of Bolts, Screws, nuts and the likes. Hi glazier, I'm not sure this is can help you or not,but try it http://www.acfcom.com/ Quote Link to comment Share on other sites More sharing options...
Fullsail Posted July 29, 2006 Share Posted July 29, 2006 https://reidecom.reidtool.com/xephr/qbe/REID_CAD Gary Quote Link to comment Share on other sites More sharing options...
Sudath Posted September 10, 2010 Share Posted September 10, 2010 I have found a very good fastener library it has 2d and 3d in about every thing you could need.http://www.mcmaster.com How do I use them in my ACAD drawing? Quote Link to comment Share on other sites More sharing options...
AIC Concepts Posted January 11, 2013 Share Posted January 11, 2013 How do I use them in my ACAD drawing? Here i've sent you a screenshot showing the location of the CAD file, let me know if it works. Quote Link to comment Share on other sites More sharing options...
dirtyDUPE Posted February 19, 2013 Share Posted February 19, 2013 I'm able to download the 2D DWG or DXF from the McMaster-Carr site (excellent resource) and open them with no issue but none of the 3D files seem to work. Has anyone had any luck with the other files? Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 19, 2013 Share Posted February 19, 2013 Given that there is no DXF or DWG choice for a 3D version wouldn't you have to import a file type that AutoCAD does support? Quote Link to comment Share on other sites More sharing options...
dirtyDUPE Posted February 19, 2013 Share Posted February 19, 2013 Given that there is no DXF or DWG choice for a 3D version wouldn't you have to import a file type that AutoCAD does support? Yes, I would think so. Being new to CAD, I'm not very familiar with all the file types it supports. But I think I found a solution: Download the 3-D SAT file and import it via File>Import Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 19, 2013 Share Posted February 19, 2013 Just use the IMPORT command and see what file types are listed. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted February 19, 2013 Share Posted February 19, 2013 Some of the SAT files on McMaster-Carr do not work, in that instance (or anytime if you like), you can open most of those with Inventor Fusion and save as AutoCAD .dwg. Quote Link to comment Share on other sites More sharing options...
drwhite Posted July 1, 2014 Share Posted July 1, 2014 Had lots and lots of success with the STP files. I use Inventor and I can put the STP files directly in an assembly. It is automatically converted to an .ipt file. Quote Link to comment Share on other sites More sharing options...
drwhite Posted July 1, 2014 Share Posted July 1, 2014 I'm able to download the 2D DWG or DXF from the McMaster-Carr site (excellent resource) and open them with no issue but none of the 3D files seem to work. Has anyone had any luck with the other files? I've lots of luck with the STP files in Inventor. Can be opened directly or inserted into assemblies. Automatically converted to .ipt file. Quote Link to comment Share on other sites More sharing options...
Rebel Posted November 12, 2014 Share Posted November 12, 2014 I know this is an old thread, but I haven't been here in a while and didn't see the method I use posted. With the McMaster library, use the 3d-SAT option and save the file to wherever you wish. Navigate to the file and drag it into your drawing (ie. if you saved the file to your desktop go there, click & drag the file into the drawing you need in autocad). It will be at 0,0. Hope this helps! I use mcmasters library quite a bit for odd/specialty fasteners that aren't in our library. Just make sure and check the scale. I've had some that didn't come in right and had to scale them (down, usually. I suspect some objects were drawn metric) Quote Link to comment Share on other sites More sharing options...
Murphy625 Posted August 7, 2015 Share Posted August 7, 2015 Yes, I would think so. Being new to CAD, I'm not very familiar with all the file types it supports. But I think I found a solution: Download the 3-D SAT file and import it via File>Import That's awesome!!! It works! Thanks! Quote Link to comment Share on other sites More sharing options...
