education Posted December 9, 2010 Share Posted December 9, 2010 HI well i have a issue which i am going through from long time.. i have a block drawing where i have drafted many designer furniture and lights so i can use them in my design. but the moment i copy any block from this block drawing to any other drawing , my autocad screen gets hang. it says "duplicate definition of block _open90 ignore" and after this i tried searching for that block and deleting it from my block drawing but wen i say purge. it doesnt get purged . and i am not able to purge that block . i tried all possible options , googled through this issue but found no solution. finally i am here writing you all about this problem.. pls show me a solution. some one please help me in this issue cos it takes a lot of time to paste those blocks Quote Link to comment Share on other sites More sharing options...
hazardman Posted December 9, 2010 Share Posted December 9, 2010 i beleive "open90" is a tick block for a dimension string...if the dimension style is in both drawings then you want be able to purge it... Quote Link to comment Share on other sites More sharing options...
rkent Posted December 9, 2010 Share Posted December 9, 2010 I would insert _open90 block somewhere in the drawing. Now explode it. Now list what is left behind. Is it a block named _open90? If so then you will need to edit the _open90 block so you don't have a block within a block with the same name. No need to have a block within a block so edit it to remove that. Quote Link to comment Share on other sites More sharing options...
