jasebro Posted December 9, 2010 Posted December 9, 2010 I am having a problem when I am in ps and I go to zoom into the object to snap or to add objects (still in ps) and the image of the viewport (ms) zoom in as well which is very annoying to work around It., any idea would be appreciative Quote
Daftlad Posted December 9, 2010 Posted December 9, 2010 Go into paper space and select the viewport and open properties in the modify tab. Scroll down the bottom and see if vp locked is yes or no. Change it to what you want. I always set my scale and then lock the viewport and work from there. I don't know if this makes much sense as its still early. Hope this helps. Quote
jasebro Posted December 9, 2010 Author Posted December 9, 2010 i made sure that vp lock is on or off, it was off. so i selected the scale and then lock it and still same problem Quote
jasebro Posted December 9, 2010 Author Posted December 9, 2010 it happens only in 3d visual styles Quote
jasebro Posted December 9, 2010 Author Posted December 9, 2010 I have found the answer to my problem, if anyone has come across this problem. The best way to fix the problem is go into Tools>Options, then click system tab. click on performance settings, then click on manual tube and turn off the enable hardware acceleration and CLOSE the autocad program, reopen and the problem is solve!!! Quote
irneb Posted December 9, 2010 Posted December 9, 2010 jasebro said: I have found the answer to my problem, if anyone has come across this problem. The best way to fix the problem is go into Tools>Options, then click system tab. click on performance settings, then click on manual tube and turn off the enable hardware acceleration and CLOSE the autocad program, reopen and the problem is solve!!!That sounds like there's a problem with your graphics card or its driver. Try to get hold of the recommended driver for your particular card - it's not necessarily the newest, but the best tested. If there isn't one, you may need to look at getting another card. Turning the HW-Accel off is going to make rotates, pans and zooms in 3D slower. Quote
