Guest NUBBZ143
I have a dynamic block with two linear stretch actions. I can change the linear dim's through the properties but I can't select the stretch grip and drag. Tried placing the block in a new drawing, no change. Any suggestions?
Section Label Block.dwgFetching info...
I opened up your drawing and was able to move the lines with the arrows???? - Using Autocad 2011
Your block is also annotative. The block is set to 1:16, but the CAnnoScale is 1:1. Change the CAnnoScale (the pop-up at bottom-right of status bar) to 1:16 as well. You should then be able to grip edit the DB parameters.
For some reason 2008 doesn't allow grip edits to DB's when the 2 scales don't match. I think that's fixed in newer acads (like Grant's shown).
