how can surface styles be removed once applied?
Removed from that part, or deleted?
go to material/color style right click on style you want to delete > purge style/purge style and sub-style
Edited by Be_cool
How to change texture orientation, but only on 1 surface...?
i have gone into the inventor studio environ ment and assigned surface styles, i want to remove the assigned styles from the part....
you don't have to go in Inventor Studio environment to edit or add new style...just do it from part envirement.
i know you don't, but in inventor studio you can select each surface rather than a feature. But now im further into my design i have realised i dont need to do this and can just use the feature textures like you have shown above. Hence why i need to find out how to remove the surface styles i have applied as the material selection doesnt override the surface style that i selected....
if that makes sense :/
even in this case you don't have to go in Studio, just right click on surface that you want to change>properties>and pick style
Second part of your post i didn't figured out. Painless solution is to start angain new part and all styles will be back to normal ( ofc. if you didn't change template, but I'm shure you didn't).
hmm i'll have a bash! thanks for the assistance dude :)
We are here to help each other...
Regards
Aleksandar
