Hey there,
I took pipe drafting years ago. I forgot the correct steps in drafting a 90 deg pipe bend in 2d (autocad)? Anyone know thanks :geek:
If you're just looking to draw the fitting, I'd draw the centerline, then offset, then close the ends.
Here's a quick demo for a 6" LR90 (My standard fittings are actually all blocks, but you get the idea)
http://screencast.com/t/13fxRXjqTbG1
Any good piping book will have all the necessary dimensions required for drawing fittings.
Another option is to skip drawing them yourself and get them as a free download or buy a set of pipe fitting symbols from any number of sources.
I worked at a copper tubing fabrication place for many years, we did tubing this way. Your mileage may vary.
  Bowmen said:
Hey there,
Russ Steffy made a good program for pipe, flanges and elbows.
It will draw regular and segmented elbows.
http://www.spaug.org/LISP_Index01.Html
Short radius elbows - the center line radius will be 1.0 x nominal dia of pipe.
Long radius elbows - the center line radius will be 1.5 x nominal dia of pipe.
