irneb Posted December 6, 2010 Posted December 6, 2010 Lee Mac said: I don't believe the location of the .lin file in which the linetype may be defined is disclosed, one would have to search all .lin files for the appearance of the definition should it be there at all.You're correct! The linetype definition is saved within the DWG - in the LTYPE table. You can of course save the DXF data for the linetype, so this can be re-imported into another DWG without even having the LIN file. Although complex linetypes may cause problems - as the SHX is not saved within the DWG. As another thing: most XML viewers complain about "whitespace". That "shouldn't" be, but usually a XML file does not contain new lines and spaces between tags. It's a bit silly I know, but what can you do? You may want to try using MS's XML parser to have it format the XML file for you instead of doing it manually: (setq xml (vlax-get-or-create-object "Msxml2.DOMDocument.5.0")) You may also want to make the XML compatible with Excel, instead of creating a link to Excel using COM (when and if you do the one DWG / per tab idea): http://msdn.microsoft.com/en-us/library/aa140066%28office.10%29.aspx It should be much faster to generate the XML file without needing to load Excel and use its ActiveX interface. Quote
Lee Mac Posted December 6, 2010 Author Posted December 6, 2010 Thanks for the ideas Irneb! I'll certainly look into the links you have provided and see what I can do Quote
Lee Mac Posted December 11, 2010 Author Posted December 11, 2010 Sittingbull said: This tool is amazing!!! Thanks Sittingbull! Quote
Lee Mac Posted December 11, 2010 Author Posted December 11, 2010 wizman said: Nice One Lee! Thanks. Thanks Wizman - good to see you around these parts again Quote
Lee Mac Posted January 12, 2011 Author Posted January 12, 2011 After spending a bit of time studying XSL, I have upated the code in the first post to Version 1.3 - as you will see from the image on my site, this enables you to view the XML data in a HTML Table styled with CSS. Enjoy! Lee Quote
Lee Mac Posted January 12, 2011 Author Posted January 12, 2011 Added image to demonstrate tabular output Quote
jtk07 Posted January 14, 2011 Posted January 14, 2011 Lee, Is it possible to take the program you currently have created and use it instead of layerstates? for example what if you could export a list of layers and all there characteristics, modify them to your liking in say excel or csv. Reimport them to a folder containing any amount if files. the control of plot styles line weights colors would all be a thing of the past on file at a time. your the MASTER great program thus far! Quote
Lee Mac Posted January 14, 2011 Author Posted January 14, 2011 jtk07 said: what if you could export a list of layers and all there characteristics, modify them to your liking in say excel or csv. Reimport them to a folder containing any amount if files. the control of plot styles line weights colors would all be a thing of the past on file at a time. As you can imagine, the 'import' question has actually already been asked (elsewhere), the difficulty arises as I have offered so many different formatting options for the user to export the data, so the program would have to be set by the user to exactly match the format of the data - not impossible, but certainly difficult. jtk07 said: your the MASTER great program thus far! Thanks mate! Quote
Lee Mac Posted May 2, 2011 Author Posted May 2, 2011 irneb said: You may also want to make the XML compatible with Excel, instead of creating a link to Excel using COM (when and if you do the one DWG / per tab idea): http://msdn.microsoft.com/en-us/library/aa140066%28office.10%29.aspx It should be much faster to generate the XML file without needing to load Excel and use its ActiveX interface. Finally got around to adding this functionality to the program If you choose to write the output to an XML file, there are additional options as to whether the XML file is created using XML Spreadsheet Schema (XMLSS) and also whether an XSL Stylesheet is generated (to create the output shown in the description my site). New Version here. Lee Quote
Organic Posted November 28, 2011 Posted November 28, 2011 It is probably just me failing to use it correctly, although when I try to use it I keep getting the error "** Error: too few arguments **" (when the drawing does in fact have multiple layers in it). Quote
Lee Mac Posted November 28, 2011 Author Posted November 28, 2011 Dink87522 said: It is probably just me failing to use it correctly, although when I try to use it I keep getting the error "** Error: too few arguments **" (when the drawing does in fact have multiple layers in it). Hi Dink, Seems like you're having a bad day with my programs! I've just tested the latest version of this program (LayerExtractV1-4.lsp), and cannot seem to reproduce the error that you are reporting. At what point do you receive the error? i.e. Before the dialog appears, or after? Lee Quote
baker Posted November 28, 2011 Posted November 28, 2011 bumping a very old thread. I am sorry. Anyway you can add a function to print to a table in AutoCAD where each line is on the layer it describes? Someone made a lisp for this recently in another post and it works, but i like the dialog box and the ability to select what you want to have displayed. Quote
Lee Mac Posted November 29, 2011 Author Posted November 29, 2011 Hi Jon, I'll see what I can do if I get some time. Lee Quote
