Jpier Posted November 29, 2010 Posted November 29, 2010 I have my layers property manager docked on the side of my screen. Whenever I select it to add a new layer, it closes up right after I enter info for a specific layer. I am pretty sure that before, I was able to keep the layer property manager open for an extended period of time so that I could enter info for multiple layers all at once. Is there some setting that I inadvertently flipped that causes it to close prematurely? Quote
Tiger Posted November 29, 2010 Posted November 29, 2010 [ATTACH]24856[/ATTACH] On your Properties panel at the top right side (or left, but its the right side in this image) underneath the x-icon is another icon that you can click. click that til it looks like in this picture (two arrows and a line) and it should stay open. Quote
ReMark Posted November 29, 2010 Posted November 29, 2010 (edited) Disable "Auto-hide" and you should be able to put in multiple layers without the LPM disappearing on you. I seem to recall, as you do, that this behavior was not the "norm" in the past. I believe it is yet another example of AutoDesk deciding on their own, without the benefit of their users, to change the way some features work because a programmer has decided that's what we want or need which is not always the case. I could cite other examples but what would be the point? No one listens anyway. Edited November 29, 2010 by ReMark Quote
Jpier Posted November 29, 2010 Author Posted November 29, 2010 I took your advice and was able to disable autohide. I think that will do the trick. Thanks Quote
Jpier Posted November 29, 2010 Author Posted November 29, 2010 Thanks for the tip. Using your picture, I was able to get the situation conrrected. Quote
Robert Cad Posted September 12, 2019 Posted September 12, 2019 2019 and this is still an issue. When docked and you un-check auto-hide, the Properties field it so large it bleeds off the screen. I un-docked so I could reduce the size to what I actually need, and left off auto-hide. Later (different day) I encountered the same problem described above: as I was trying to edit layers the damned thing would disappear. Checked properties and found it had reverted to auto-hide. Frustrating. Other problem: when Properties is not docked, and I'm on a dual monitor but using ACAD in just one, the properties box sometimes opens in the other monitor, which is where I least expect to find it. Agreed, Autodesk -- like Microsoft -- seems to change simple and functional operations for no good reason...other than, perhaps, to continually sell training. Quote
RobDraw Posted September 12, 2019 Posted September 12, 2019 Still an issue? This thread has had zero activity for nearly 10 years. Quote
SLW210 Posted September 13, 2019 Posted September 13, 2019 I have no problems with it. I only open it when needed, then close it when done, it has never disappeared on me. The OP solved it by disabling Autohide, seems you have a different problem. 1 Quote
