HaxLi Posted November 28, 2010 Share Posted November 28, 2010 (edited) Question: Is it possible to Map Material in the Block? Why do I want that? Just made one block of stair, and copied them that I could do changes to all of them by one modify. I want to fix the wood material map in that Block EDIT: Found a way how to rotate material, by rotating object by 90, add material again, and rotate 90 it back I wonder is it possible to bypass those blocked command in Block? Edited February 5, 2011 by HaxLi found semi-answer Quote Link to comment Share on other sites More sharing options...
Raudel Solis Posted February 5, 2011 Share Posted February 5, 2011 Hey im not sure exactly what your asking, but if your material is unalligned ( not at a factor of 90 degrees) then you can go under the render tab and find material mapping and select box. and when it prompts to select something from the model you can hold ctrl and select an individual face. you can figure it out, also if you right click theres a move and a rotate option as well as a reset option to return to previous state Quote Link to comment Share on other sites More sharing options...
HaxLi Posted February 5, 2011 Author Share Posted February 5, 2011 My question was how to Material Map in Block Edit (BEDIT) mode Quote Link to comment Share on other sites More sharing options...
fahim108 Posted February 5, 2011 Share Posted February 5, 2011 AutoCAD sucks at times... I know! But you can always use the good ol' REFEDIT command (Xref and Block In-place Editing command). You can use the material mapping option in that... cheers! Quote Link to comment Share on other sites More sharing options...
