aleair Posted November 25, 2010 Posted November 25, 2010 (edited) Hi everybody, I'm new with autocad. Actually it's my first time I need to write a VBA procedure for autocad. That's the reason why I'm posting this thread. I have blocks with attribute. In one of this attribute I want to insert an expression that calculates a polyline area. Doing it manually works. the expression is: "%%).Area>%" where 2130001176 is the ObjectID of the specific poly. I tried to insert the expression via vba with this code: attArr = oBlkRef.GetAttributes attArr(3).TextString = "%%).Area>%" It doesn't work and the value (corresponding to the poly area) is not calculated. Only "####" is shown as value. Any idea how to insert the expression via VBA? Edited November 25, 2010 by aleair error Quote
BIGAL Posted December 1, 2010 Posted December 1, 2010 I think you need 2 extra line area ="%%).Area>%" attArr(3).TextString = area attarr(3).update found this Sub Example_Area() ' This example creates a polyline object and ' then uses the area property to find the ' area of that polyline. Dim plineObj As AcadLWPolyline Dim points(0 To 5) As Double Dim plineArea As Double ' Establish the points for the Polyline points(0) = 3: points(1) = 7 points(2) = 9: points(3) = 2 points(4) = 3: points(5) = 5 ' Create the polyline in modelspace Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points) ' Close the polyline and update display of it plineObj.Closed = True plineObj.Update ZoomAll ' Get the area of the polyline plineArea = plineObj.Area MsgBox "The area of the new Polyline is: " & plineArea, vbInformation, "Area Example" End Sub Quote
aleair Posted December 1, 2010 Author Posted December 1, 2010 found solution, thanks. Attrib.TextString = "%%).Area \f " & Chr(34) & "%lu2" & Chr(34) & ">%" where Cstr(id) is poly objectID Quote
